976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 04, 2026, 01:25 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Rear brake issue - where how and what type ?
Author Topic: Rear brake issue - where how and what type ?  (Read 2640 times)
Offline mattlfc
« on: August 18, 2013, 04:00 PM »
Dumb dumb dumb question....
My latest purchse didn't come with a rear brake - thats fine I thought - I'll just wack one on - however....
I can't figure out how the brake is meant to mount as there is no usual top bracket rear mounting.  The mounting seems to be on trhe lower bracket.  That means if I try and put a standard MX side pull lever it winterferesd with the pedal arm.
So...
Is there a special rear brake assembly for lower bracket mounts?  Or am I completely missing something ?
Help!  Please   :-[
leehunt1
Re: Rear brake issue - where how and what type ?
« Reply #1 on: August 18, 2013, 05:04 PM »
can u show us a pic of brake mounts ..?
I have a rear AD990 which u may need
Offline Bigfrawg
« Reply #2 on: August 18, 2013, 05:25 PM »
You could try a pitbull
Offline mattlfc
« Reply #3 on: August 18, 2013, 05:38 PM »
It has a hoop bar at the top but that does not have a hole drilled to mount brakes.
It has what I would consider a mounting bracket at the bottom on the lower strutt.
Offline Dannywhac
  • return of the whac
« Reply #4 on: August 18, 2013, 05:52 PM »
Offline chubby
  • Needs Pegs
« Reply #5 on: August 18, 2013, 06:00 PM »
Nail whatever brake you want in the hole down there  :daumenhoch:
Offline mattlfc
« Reply #6 on: August 18, 2013, 06:03 PM »
can't - standard side lever interferes with pedal arm as sticks out too much    :(
Offline chubby
  • Needs Pegs
« Reply #7 on: August 18, 2013, 06:37 PM »
What you expect I am pi$$ed  ;D
Does it catch if you put it underneath ???
« Last Edit: August 18, 2013, 06:40 PM by chubby »
Offline GavinDavis
« Reply #8 on: August 18, 2013, 09:17 PM »
I would either try mounting a caliper to the very underneath of the frame, as thats how it looks as though it designed to be ran.  Or maybe use the coaster bracket for a coaster brake  :daumenhoch:
It may well need a specific caliper though, like the one that the mongoose decade ran  :daumenhoch:
Offline not johndub71
« Reply #9 on: August 19, 2013, 08:06 PM »
What about a plate and a ubrake?
Facebook/Fr35Hair
Offline Gnarlyscoots
  • BANNED
« Reply #10 on: August 19, 2013, 08:29 PM »
You need one of these mounted from underneath  :daumenhoch:
Dia Compe 750 caliper.
BANNED
Offline mattlfc
« Reply #11 on: August 20, 2013, 06:47 PM »
Superb!  Thx!
Now next obvious question.....
Any idea where I would purchase one of those ???
Offline mattlfc
« Reply #12 on: August 20, 2013, 06:50 PM »
its ok - if I'd bothered to google for 5 seconds i would have had my answer   :-[
