976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 27, 2026, 12:29 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Axles..
Author Topic: Axles..  (Read 2180 times)
Festerfly
Axles..
« on: August 07, 2006, 05:47 PM »
I have a new shiney set of wheels on which the axles measure just over 12mm in Dia....
the problem i have is that both my frame and forks have 10mm cutouts.. is it just the simple thing of filing back the cutouts until the axles fit or is there more to it?
also.. does anyone know how to get rusty brown pitting marks out of a chrome frame without having to strip it all and rechrome?
Thanks
motomagII
Re: Axles..
« Reply #1 on: August 07, 2006, 07:34 PM »
dont touch the frame flat 2 opposite sides of the axles until they fit .thats the way i did mine
silentpartner
Re: Axles..
« Reply #2 on: August 07, 2006, 07:43 PM »
greg's right just file the sides down equally.
fine guage wire wool should move most rust spots, then polish with a decent polish, autosol, peek, auto gleam
alan  ;)
duncan
Re: Axles..
« Reply #3 on: August 07, 2006, 09:37 PM »
I used the method described by Alan for a set of bars, worked a treat.
For deeper rust on a Cr-Mo stem I have, I got Hammerite Gel rust remover.
Put it on a millimetre or so thick and leave until you can see the rust blacken underneath, then wire brush the rust off.
Repeat if necessary and the rust is gone, just clean bare metal left that you can protect with polish/wax/lacquer etc.
Re: Axles..
« Reply #4 on: August 07, 2006, 09:50 PM »
buy a new file
axles is hard.
weston
Re: Axles..
« Reply #5 on: August 07, 2006, 10:03 PM »
buy some gt wheels from an old performer 90ish, they had these axles
Festerfly
Re: Axles..
« Reply #6 on: August 09, 2006, 10:15 AM »
will it not weaken the axles filing those back though?
also, the width of the front forks seems to narrow to fit my wheels into?
silentpartner
Re: Axles..
« Reply #7 on: August 09, 2006, 05:32 PM »
if the axle is 12mm, and you need 10mm your only taking 1 mm off the top and bottom side, basicaly the thread. or get some mid-school GT axles like western says.
maybe their junior forks? made for 1 3/8 wheels/tyres?
alan  ;)
