976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 03, 2026, 02:21 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Removing annodising
Author Topic: Removing annodising  (Read 1386 times)
Offline phantom photon
Removing annodising
« on: September 24, 2013, 02:05 PM »
I know Oven Pride is the tried and tested way or removing annodising but just wondering if anyone has tried the Mighty Oven Cleaner from Poundland  ???
Re: Removing annodising
« Reply #1 on: September 24, 2013, 02:23 PM »
I bought some shaving foamy type stuff in a can from the pound shop that worked just as well so yes go for it :daumenhoch:
Offline insectbones
« Reply #2 on: September 24, 2013, 02:40 PM »
If it doesn't work, you've only wasted a quid. Try it, and let us know the results  :daumenhoch:
Offline Munnyella
« Reply #3 on: September 24, 2013, 07:51 PM »
I used some of that, but for some strange reason, I cleaned the oven with it!!
It seemed to work better than Oven pride too, but that was on dead pizza and misc. fat based food stuffs.
Gotta be worth a go.
MM
Offline kalex
« Reply #4 on: September 24, 2013, 08:06 PM »
Caustic soda granules
About 250grams for a quid from the cheapo shops
Offline scoff
« Reply #5 on: September 24, 2013, 08:22 PM »
Sainsbury's value costic soda, about a pound? Mix it with water in a large tub and chuck your rims in, it should bubble and leave a residue on them, clean it off with wire wool, Bingo.
« Reply #6 on: September 24, 2013, 11:18 PM »
Thanks guys  :daumenhoch:
Got a few things to do so will try a couple of the methods above to see which works best.
« Reply #7 on: September 25, 2013, 06:19 PM »
Put some before and after pic's up.  :daumenhoch:
