976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 03, 2026, 11:42 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Powder coating removal advice please
Author Topic: Powder coating removal advice please  (Read 3137 times)
Offline Taipan
« on: October 10, 2013, 03:28 PM »
What do you use that's readily available? I have some starchem Synstrip but it wont touch It!  :(
Offline Funkyworm
Re: Powder coating removal advice please
« Reply #1 on: October 10, 2013, 03:35 PM »
Should do.
If you can submerge the item in Sinstryp then do it & give it time,  if you cant submerge the item try to place the it in a sealed container otherwise it starts to evaporate & dry out.
I placed a seat post in a heavy duty rubble bag & poured in the sinstryp & sealed the bag, it still took 2 days keeping the bag outside.
its not a quick process , if you are doing it indoors make sure it's a very well ventilated room,  failing that if you are sending the item to Dan for paint or powder he'll do it for you. :daumenhoch:
« Last Edit: October 10, 2013, 03:37 PM by Funkyworm »
Offline Taipan
« Reply #2 on: October 10, 2013, 03:38 PM »
Its a Frame so haven't enough to submerge it,I'm thinking of going to a car body paint shop and asking them as they must have something that would strip it easily?
Offline Funkyworm
« Reply #3 on: October 10, 2013, 03:47 PM »
They all use synstrip from what i can gather (Paint is different to powder coat & comes off quicker ) . its not a quick process mate, i've done frames outside painting it on scraping a bit off using a wire brush etc then doing some more & it takes time (2-3 hrs) at least in some cases.
 The only other product ii know of is s (Permotex Gasget remover) but I think you have to buy it in from abroad.
Offline Taipan
« Reply #4 on: October 10, 2013, 04:05 PM »
Thx for the info fella :daumenhoch: I might just set fire to it and burn it off lol
Offline Funkyworm
« Reply #5 on: October 10, 2013, 05:31 PM »
Do it !  :slayer: :2gunsfiring_v1: :LolLolLolLol:
Offline rick1970
« Reply #6 on: October 10, 2013, 07:13 PM »
I used nitromors
Offline sawzall
« Reply #7 on: October 10, 2013, 09:16 PM »
im sure i remember someone using gasket remover ???
« Last Edit: October 10, 2013, 09:30 PM by sawzall »
Offline Dannywhac
  • return of the whac
« Reply #8 on: October 10, 2013, 09:27 PM »
I've used gasket remover (spray on) - works well, just as good (I've found) as Synstrip but costs more as a can will barely do a frame.
rodriguez
« Reply #9 on: October 10, 2013, 10:05 PM »
Yup, I've used gasket remover, loctite 7200, swore I'd just get it blasted next time.
Offline Diesel1
« Reply #10 on: October 10, 2013, 11:18 PM »
You could also try a 'burn off oven'.  Some powder coaters have them.
Simon.
Live by the Burner.  Die by the Burner.
RetroRich78... "No probs buddy I was coming if it was only you and I. Well done mate great day"
That is the best compliment I could wish to receive.
Offline Gary72
« Reply #11 on: October 10, 2013, 11:34 PM »
Is it a Mountain bike frame? I have spoken with SBD before and some of the MB frames have a stone chip proof coating and Dan has even had problems stripping them.
Offline kev-s
« Reply #12 on: October 11, 2013, 03:53 PM »
ive had problems using synstrip on a powdered frame, the powder job was done in the mid 90's so was very thick and ive been told its different to the powder used today
best bet is to get it sand blasted/shot blasted by your local powder coater and generally costs less then a 5lt tub of synstrip :daumenhoch:
Offline Taipan
« Reply #13 on: October 11, 2013, 04:47 PM »
Its a generic bmx frame but it is early 90's so could have the bomb proof powdercoat mentioned above  :(
Offline Si-ET
« Reply #14 on: October 11, 2013, 07:43 PM »
I use this stuff. Works a treat on powder coating, paint and superchrome. If you do use it on superchrome it don't affect the chrome underneath.👍👍👍
« Reply #15 on: October 11, 2013, 07:56 PM »
I had a frame once that was powdered but had almost a plastic finish to it, very strange stuff. Anyway the only thing that removed it was sand blasting.
Offline Diesel1
« Reply #16 on: October 11, 2013, 08:51 PM »
Could that have been Tough-Coat-Dynol?  My dad had a VW Golf in 1985 that was treated with a plastic coating.
Simon.
« Reply #17 on: October 11, 2013, 09:09 PM »
Simon.
Not too sure what it was called, Synstrip etc etc didn't come close to shifting it
