976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 03, 2026, 09:09 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Oxy Bath.
Author Topic: Oxy Bath.  (Read 1970 times)
Oxy Bath.
« on: October 11, 2013, 07:19 PM »
What's involved, and how do you do it?
Any advice guys? ???
Offline martin46
Re: Oxy Bath.
« Reply #1 on: October 11, 2013, 07:29 PM »
You can buy small tubs on Ebay and you'll need an old baby bath or a builders/plasterers mixing bath, or maybe even a paddling pool will do. You'll have to experiment with mix ratios, start weak and add more oxy as required. once you have it right, a 12 hour soak should be enough to shift the rust. Then just rinse and polish  :daumenhoch:
Re: Oxy Bath.
« Reply #2 on: October 11, 2013, 07:29 PM »
I use a wheelie bin. Half a bottle of oxy crystals. Leave for about 12 hours. Dont leave in too long if the chrome is thin.  :daumenhoch:
Re: Oxy Bath.
« Reply #4 on: October 11, 2013, 07:38 PM »
fill up some big bottle with water a place then in the tub - this will lower the volume of water and mix, so you can use less mix and still fill the tub  ;)
Re: Oxy Bath.
« Reply #5 on: October 11, 2013, 07:40 PM »
Will an oxy bath damage decals ? I assume it will but have never done one so don't know.
Offline fischflo
Re: Oxy Bath.
« Reply #6 on: October 11, 2013, 07:45 PM »
Re: Oxy Bath.
« Reply #7 on: October 11, 2013, 07:45 PM »
Good tips as always chaps.
I'm sure I heard of someone using citric acid? :-\
I can get loads of that stuff from work.
Fortunately, it's only a set of forks I need to do. :daumenhoch:
Re: Oxy Bath.
« Reply #8 on: October 11, 2013, 07:47 PM »
In my experience YES  ???
some decals may be safe, but I have seen foil one's go south big time - if you want to save the decals, then go the hand polish Peek route
you might find that vinyl decals survive - but can't be 100% - so it up to you to chance it or not  :pilky:
Offline fischflo
Re: Oxy Bath.
« Reply #9 on: October 11, 2013, 07:52 PM »
foil ...like the mongoose ones? .....interesting, good to know that :daumenhoch:
Re: Oxy Bath.
« Reply #10 on: October 11, 2013, 07:54 PM »
Better still send my bars down to you  :daumenhoch:
Offline Dannywhac
  • return of the whac
Re: Oxy Bath.
« Reply #11 on: October 11, 2013, 10:27 PM »
Citric acids better in my experience. Get this:
http://www.ebay.co.uk/itm/CITRIC-ACID-1kg-Purest-Food-Grade-Anhydrous-Descaler-Bath-Bombs-/300922191152?pt=UK_HeathBeauty_BathShowCons_RL&hash=item46105c3d30
Wait till the missus is out (then she can't stop you)/have a bath suite you're about to replace cos it came with the house, pop a couple of buckets full of water in the bath so there's less volume of water in there, pop frame(s) in, cover the frame with water and bang about 250g of Citric to start with. Wait 6 hours or so and give the frames a go over with an old tooth brush. If the rusts not shifted, bang a bit more citric in and brush again. Rust should be gone in 12 hours-ish. Rinse the frames afterwards to get rid of any acid left - bonus is n'all it cleans the bath and trap  :daumenhoch:
rodriguez
Re: Oxy Bath.
« Reply #12 on: October 11, 2013, 11:05 PM »
If you can get the citric acid for free go for that, just as good and less likely to damage chrome as BMX1973 mentioned.
