976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 03, 2026, 09:09 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Goose forks !
Author Topic: Goose forks !  (Read 2000 times)
Goose forks !
« on: October 13, 2013, 05:47 PM »
which model do each of these forks belong to ?
cheers B  ???
Offline kalex
Re: Goose forks !
« Reply #1 on: October 13, 2013, 11:41 PM »
i'm not saying this is your answer B
but my 83 cali sloping forks like on the left, i didn't really notice it till i had my motomag next to it, and they had more rounded shoulders like the right side one's ( albeit with pinched drops)
also though don't pro class have different fork dimensions to std goose's
Offline insectbones
Re: Goose forks !
« Reply #2 on: October 13, 2013, 11:53 PM »
Forks on the right came on motomags from around '81 i think....
And on the left, later, maybe 83ish  :-\
Re: Goose forks !
« Reply #3 on: October 14, 2013, 09:07 AM »
left set are from a '95 Expert and the other set I picked up spare - but I did put the tange pinched forks on the '81 team as it was a Jan model and could have had either
I do have the 7/8's on the Dec '82 Supergoose and the '81 Team/Supergoose candy blue
Re: Goose forks !
« Reply #4 on: October 14, 2013, 06:08 PM »
+1 on what Kalex says.
I have a survivour 84 Mongoose Californian and it has the forks on the left.  :daumenhoch:
« Last Edit: October 14, 2013, 06:10 PM by BMX1973 »
Offline oldschoolrb
  • im all goosed out
Re: Goose forks !
« Reply #5 on: October 14, 2013, 07:39 PM »
These are proclass forks  ;)
The key cut on your forks are on the front b ! Iv also seen that on minigoose forks
Re: Goose forks !
« Reply #6 on: October 14, 2013, 08:37 PM »
the right sided forks are Tange - the others are not marked
Key cut ?
Offline insectbones
Re: Goose forks !
« Reply #7 on: October 14, 2013, 08:43 PM »
Yep that would be correct  :daumenhoch:
Offline kalex
Re: Goose forks !
« Reply #8 on: October 14, 2013, 09:19 PM »
Key cut ?
the section where the lock washer fits in to
Re: Goose forks !
« Reply #9 on: October 14, 2013, 10:45 PM »
I just thought they were cut then welded up and where the key cut ends up can be random  :crazy2:
