976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 03, 2026, 09:08 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  How does your's hang ???
Author Topic: How does your's hang ???  (Read 4907 times)
« on: October 14, 2013, 11:22 PM »
Looking at a few rides I see some of you like your rear cable to hang different on the top tube !
some on top and some to the right side - a few to the left and some under the tube
so who does what and what looks best ?
cheers B  ???
Offline steve69
  • aka. Steve Changa
Re: How does your's hang ???
« Reply #1 on: October 14, 2013, 11:30 PM »
I like mine to the right but if it was with a 901 it would have to be to the left, the ones that fit them on top are usually running them with the chrome cable clamps (so the screw is fitted out of the way i.e. under the bar)
« Reply #2 on: October 14, 2013, 11:47 PM »
I run the DC clamps (chrome, not the plastic one's) and for picture shots face the DIA COMPE part out towards the right side
same as matching tyre logo up with valve cap - and taking pic's chain side
But I do wonder what people prefer ?
also rear brake left or right ? and if running a pair, is it the same side as running a single ? so does that also count which way the cable is ?
Offline insectbones
« Reply #3 on: October 14, 2013, 11:56 PM »
I always have rear brake on the left, front on the right.
« Reply #4 on: October 15, 2013, 12:02 AM »
and what about cable ?
Offline insectbones
« Reply #5 on: October 15, 2013, 12:05 AM »
On the right or underneath.
Offline kalex
« Reply #6 on: October 15, 2013, 12:24 AM »
Cable on top and rear brake lever on the left side of bars
« Reply #7 on: October 15, 2013, 12:27 AM »
so no one swaps over if they run two brakes or other way around for just rear ?
« Reply #8 on: October 15, 2013, 02:08 AM »
No, I could get confused in a sudden braking situation and end up under a bus
Offline Taipan
« Reply #9 on: October 15, 2013, 08:39 AM »
Unless you have OCD it doesn't matter?
« Reply #10 on: October 15, 2013, 08:43 AM »
Is it April 1st?  ???
Offline Julian347
« Reply #11 on: October 15, 2013, 08:49 AM »
Left if its a 901 and right for a 900/1000.
Offline Dannywhac
  • return of the whac
« Reply #12 on: October 15, 2013, 08:55 AM »
Depends which way you bar spin.
« Reply #13 on: October 15, 2013, 09:09 AM »
what if your rear brake is mounted under the chainstays?  christ my brain is fried!!!   :D
« Reply #14 on: October 15, 2013, 09:18 AM »
millions of kids are laughing at this thread .... brakes pfffffffffffffffffft
Offline Dannywhac
« Reply #15 on: October 15, 2013, 09:29 AM »
I'll say it once more - IT DEPENDS WHICH WAY YOU BAR SPIN.
Offline nosepickben
« Reply #16 on: October 15, 2013, 12:48 PM »
Back brake lever on the right, cable around the headtube and down the left side/underside of whicher tube leads to where your brake is. Anything different to that is incorrect.  :yahoo_silent:
Offline Rabdul06
« Reply #17 on: October 16, 2013, 12:08 AM »
   Front brake on the right, rear brake on left. Cable down the right side of top tube held with chrome DC clamps. This is the only way to do it and is actually law in 12 different countries..................may be.
« Reply #18 on: October 16, 2013, 12:09 AM »
 ;D
« Reply #19 on: October 16, 2013, 07:01 PM »
I always put my rear brake lever on the right, even if I have a front brake too. :-\
As for the cable if you have a frame pad installed, run it underneath through the middle of the foam.  :daumenhoch:
« Reply #20 on: October 16, 2013, 08:01 PM »
No rules here  ::) Just as it takes me  :coolsmiley:
Offline Redline
« Reply #21 on: October 17, 2013, 05:16 PM »
Rear brake lever on right  :daumenhoch:
Cable to right of top tube running through the gap in the Frame Pad  :daumenhoch:
or
Cable on top if using DC cable clamps... think the screw looks better underneath  :daumenhoch:
Offline Devilock
« Reply #22 on: October 17, 2013, 05:32 PM »
No apostrophe B...!!  :D
