976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 27, 2026, 02:01 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Getting Off Decals In As Few Bits As Possible !!
Author Topic: Getting Off Decals In As Few Bits As Possible !!  (Read 2372 times)
Offline Stace
« on: August 09, 2006, 03:17 PM »
Guys,
Just bought a General Lee frame of Retro.  I want to restore it but can't get the decals (spoke to DK in the US, was told I had no chance  ;D :D).
Anyhow, I can't find it but I'm sure one of you stars posted a way to get the decals off in a good enough  state to get repro's done!
Can ya help ?
weston
Re: Getting Off Decals In As Few Bits As Possible !!
« Reply #1 on: August 09, 2006, 03:29 PM »
are the decals laquered on like the new gt's? if not warm up with a hairdryer & peel off, the residue thats left will come off quite easily with meths or lighter fuel
Jazzchimp
« Reply #2 on: August 09, 2006, 03:32 PM »
Not easy but this is how it's done.
Lightly tip lighter fluid (you can get this at most fag counters) into the corner of the decal you want to work. Then using a scalpel or super sharp knife lift the edge. Then pour more lighter fluid into the underside and keep lifting allowing the fluid to soak in.
Another tip is to use a hairdryer to loosen the adhesive which has a low melting point.
Lighter fluid is the best stiff though.
Offline Stace
« Reply #3 on: August 09, 2006, 03:44 PM »
So assuming that I can get them off, any ideas where I can get them repro'd?
Thanks
Stace
« Reply #4 on: August 09, 2006, 04:58 PM »
"Lighter fluid is the best stiff though"
freudian slip there carl.
most good print shops should be able to do it.
i think harris has had some done before. maybe ask him.
Offline Nosnod
« Reply #5 on: August 09, 2006, 08:53 PM »
What  year is it??
Customriders do the decal pack for the 2004 model
Offline Stace
« Reply #6 on: August 09, 2006, 08:56 PM »
96/97 !
Offline danny silverstreak
« Reply #7 on: August 09, 2006, 10:06 PM »
i rest my case jazz i rest my case :LolLolLolLol:
« Reply #8 on: August 09, 2006, 10:09 PM »
im sure they are the same stickers
thru out
Offline Stace
« Reply #9 on: August 09, 2006, 10:52 PM »
Unfortnately not.
Spoke to a guy at DK in the states and he mentioned it was only the first run of frames that had the dodge car on the decal set.
