976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 03, 2026, 05:29 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Aldi welder...
Author Topic: Aldi welder...  (Read 2538 times)
Aldi welder...
« on: October 22, 2013, 01:59 PM »
Thinking of getting one of these just to have in the man shed for the odd occasion i need it. Beeing a man of wood i dont have a great deal of experience with welding so is it worth getting for the odd diy job or would i just be throwing money away?  :-\
https://www.aldi.co.uk/en/specialbuys/thursday-24th-october/product-detail/ps/p/arc-welder/
Offline mattuknc
Re: Aldi welder...
« Reply #1 on: October 22, 2013, 02:17 PM »
Seen these at Aldi before, personally I wouldn't bother.  Might be ok for doing the floor pan on a Ford Transit, or blowing holes in tin cans?!
'15 PK Ripper - '13 Mankind Action - '12 Skyway TA XL - '04 King Bike Co Trial - '02 Hoffman EP -  '83 Mongoose Expert
Re: Aldi welder...
« Reply #2 on: October 22, 2013, 02:36 PM »
In before Pickle  :teef:
Offline fugazi
Re: Aldi welder...
« Reply #3 on: October 22, 2013, 02:50 PM »
Arc welders should never go near a bicycle. Great for welding the box section chassis of a car trailer though  :daumenhoch:
Re: Aldi welder...
« Reply #4 on: October 22, 2013, 03:07 PM »
You might just get what you pay for ?
I can see one of those seventies adverts coming up - NO DANNY DON'T TOUCH (BANG !) IT  :crazy2: :buck2:
Re: Aldi welder...
« Reply #5 on: October 22, 2013, 03:32 PM »
The only reason why i am considering it is for general use not bmx stuff  :shocked:
Their previous ones have needed a 30 amp socket to run from but these look like they may be different  ???
Offline oldtired
  • Dirty Old Man
Re: Aldi welder...
« Reply #6 on: October 23, 2013, 07:09 PM »
i've got a Hilka one had it years ,runs off normal plug ,  up to 140amp arc, thermal cut off etc,  1.5 to 3mm rods ,  great for general blob welding,  knocking up fly off ramps  :daumenhoch: very good for spot welding handle bar extensions in place  :daumenhoch:,
 have used it to fill dints in tubes but its a bit of a gamble as to weather or not you blow a hole rather then weld   , one might be ok then an inch further down the tube it'll blow , braze or tig (dc inverter) is the only way for bike tubes ,
rods are dirt cheap from screwfix sold by weight so you get loads if you go for a thinner rod,  takes a bit of practice to get a neat weld but very satisfying once you get the hang of it ,       ticks a good few boxes in the sunday workshop danger check list too  :daumenhoch:  :LolLolLolLol:
Re: Aldi welder...
« Reply #7 on: October 23, 2013, 07:19 PM »
Sounds good. Forgot about making ramps etc  :D
Think i may have a dabble with one  :daumenhoch:
