976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 03, 2026, 05:29 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Chain tension
Author Topic: Chain tension  (Read 1918 times)
Offline stevepeanut
Chain tension
« on: October 24, 2013, 06:02 PM »
Ok, a bit of a question that I should know the answer to.
I am having difficulty getting the chain tension right on my Haro, on my old burners I have the raleigh chain adjusters so its easy to get right. With the Haro I am putting my knuckles between the tyre and the bottom bracket to push the wheel back, lining it up straight and then tightening it. But when I tighten it, I find the wheel moves a touch and the chain seems slightly slack.
Whats the correct chain tension for a bmx? and is there a tried and tested technique for bikes with out chain adjusters?
Re: Chain tension
« Reply #1 on: October 24, 2013, 06:26 PM »
I always have a few millimetres of slack, it puts less strain on the freewheel and hub. :daumenhoch:
Offline stevepeanut
Re: Chain tension
« Reply #2 on: October 24, 2013, 06:45 PM »
Mine definately needs looking at then, its more like 20mm slack.
Re: Chain tension
« Reply #3 on: October 24, 2013, 06:57 PM »
Just whip a couple of links out. :daumenhoch:
rodriguez
Re: Chain tension
« Reply #4 on: October 24, 2013, 08:20 PM »
Offline stevepeanut
Re: Chain tension
« Reply #5 on: October 24, 2013, 09:04 PM »
Get some tensioners Steve probably move again when you ride it.
http://www.ebay.co.uk/itm/Conspiracy-BMX-Chain-Tensioners-Adjusters-Tugs-10mm-or-14mm-Incl-safety-end-nuts-/251272203655?pt=UK_sportsleisure_cycling_bikeparts_SR&var=&hash=item3a80fd8d87
Check out a half link better for small adjustments.
I think I have a new set of 10mm burner copy ones in the garage, I'll have a look,  that will pull the wheel back evenly
