976314 Posts in 138996 Topics by 6434 Members - Latest Member: Darbs July 23, 2026, 09:05 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  OS brake pads
Author Topic: OS brake pads  (Read 5174 times)
Offline Devilock
OS brake pads
« on: October 29, 2013, 09:05 AM »
I'm trying to retain some authenticity on my rider but becoming fed up with the football pitch stopping distance of white DC pads & I don't want to use NS for the reason above.
Any recommendations?
Offline GavinDavis
Re: OS brake pads
« Reply #1 on: October 29, 2013, 09:07 AM »
Make some out of compressed chewing gum, and then put coca cola on your rims  :daumenhoch:
Re: OS brake pads
« Reply #2 on: October 29, 2013, 09:14 AM »
I guess you're using Tuffs?  if so not much works Rich other than clear new school pads.  for a rider i wouldn't worry to much about era correctness and brake pads
Re: OS brake pads
« Reply #3 on: October 29, 2013, 09:32 AM »
Re: OS brake pads
« Reply #4 on: October 29, 2013, 09:34 AM »
Offline Devilock
Re: OS brake pads
« Reply #5 on: October 29, 2013, 09:51 AM »
Why would you think that? !
No I'm using the other...
It's just something I want to do. If there really isn't any that will suffice then I will seek a more contemporary solution.
Re: OS brake pads
« Reply #6 on: October 29, 2013, 09:59 AM »
what wheels are you using Rich?
Offline Devilock
Re: OS brake pads
« Reply #7 on: October 29, 2013, 10:03 AM »
Campy/Weinmann.
Any suggestions Pascal?
Offline That Swan Guy
Re: OS brake pads
« Reply #8 on: October 29, 2013, 10:08 AM »
The only benefit I see of using white DC blocks on Skyways is that you don't need a bell fitted on your bike to warn people of your imminent impact with them.
I think they should produce a highway code style stopping distance for this such block/rim combo.
In the wet? Well who knows when you'll stop! "nono"
Offline Devilock
Re: OS brake pads
« Reply #9 on: October 29, 2013, 10:15 AM »
Who is using that combination?
Re: OS brake pads
« Reply #10 on: October 29, 2013, 10:26 AM »
what about brown DC blocks?  they always seem to work pretty well on normal rims  ???
i just presumed you were using Tuffs with white blocks
Re: OS brake pads
« Reply #11 on: October 29, 2013, 10:30 AM »
Re: OS brake pads
« Reply #12 on: October 29, 2013, 10:34 AM »
I've read the mathauser/kool stop salmon ones are good esp in the wet, but haven't tried them myself yet
you can get the non-finned repro mathauser very cheap
but new school squeakers will do the trick - stopped me dead on tuffs at the bottom of a massive hill on the way to Brighton when the lights turned red. They gripped so much there was a burning smell  :teef:
the squeaking would also help alert any drunken tramps to your presence at night as you rapidly approach them on the pavement
Re: OS brake pads
« Reply #13 on: October 29, 2013, 10:45 AM »
 :LolLolLolLol:  i remember that John  ;D
The salmon/black Kool stops are good......i use them on my new school set up.
Offline donnydresser
Re: OS brake pads
« Reply #14 on: October 29, 2013, 11:21 AM »
whats up with jamming your foot on to the back tyre ffs
Offline Devilock
Re: OS brake pads
« Reply #15 on: October 29, 2013, 12:04 PM »
I reiterate- I'm not looking for just a good pad, I want to know if there are any decent OS pads.
Re: OS brake pads
« Reply #16 on: October 29, 2013, 12:09 PM »
NO  ::)
rodriguez
Re: OS brake pads
« Reply #17 on: October 29, 2013, 12:28 PM »
The only old school set up known to work was a trainer wedged between seatpost and the wheel, so do that and you'll look proper old school which a groove on the bottom of you adidas kicks.
Offline Devilock
Re: OS brake pads
« Reply #18 on: October 29, 2013, 12:32 PM »
NO  ::)
I know but I felt it was going to develop into a generalised 'which pads are good'.
Re: OS brake pads
« Reply #19 on: October 29, 2013, 12:48 PM »
These are the ones I was on about Rich
http://www.yokozunausa.com/brakepadsshoes.html
Re: OS brake pads
« Reply #20 on: October 29, 2013, 01:32 PM »
Try Koolstop Continentals, they have the look you require and should work ok. Obviously, if the rest of your brake set is 'Old School then try two pieces of wet toast as this exercise will also be pointless.
An Odyssey Slic cable could be the answer.
What is your brake set up?
Offline Devilock
Re: OS brake pads
« Reply #21 on: October 29, 2013, 03:09 PM »
Thanks for the info John.
Bren it's not so much about aesthetics rather the authenticity.  Although I'm beginning to realise I may have to purchase new ones.
The set-up is 1000 with Tech 2...shock, horror, yes Tech 2...!
« Last Edit: October 29, 2013, 03:11 PM by Devilock »
Re: OS brake pads
« Reply #22 on: October 29, 2013, 03:44 PM »
in which case good luck stopping with whatever pads you use  :D
Re: OS brake pads
« Reply #23 on: October 29, 2013, 04:06 PM »
The only way a Tech2 lever ever stapped a bike was if it fell into the spokes Rich..... FFS mate, gotta be the most pointless brake set-up for a rider :uglystupid2:
As Griff siad, more chance of stopping with two bits of buttered toast...... :-\
Re: OS brake pads
« Reply #24 on: October 29, 2013, 04:17 PM »
http://www.youtube.com/watch?v=c7LrViaPq7M
