976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 03, 2026, 12:54 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  An odd question but i'm sure someone will know...
Author Topic: An odd question but i'm sure someone will know...  (Read 2507 times)
« on: November 10, 2013, 10:39 PM »
.... What are common nut and Allen sizes on old and mid school bikes?
Brake mount nut, wheel nut, seat clamp, seat guts nuts, stem bolts etc  :)
Offline Bfellows
Re: An odd question but i'm sure someone will know...
« Reply #1 on: November 10, 2013, 10:45 PM »
I've found a fair amount of US stuff is imperial if it helps........and there are some bloody weird thread pitches......
« Last Edit: November 10, 2013, 10:47 PM by Bfellows »
« Reply #2 on: November 10, 2013, 10:49 PM »
Cheers Bert.
Yeah i remember as a kid getting annoyed at the imperial/metric difference. Just enough play to chew your nuts up  >:(
Offline Bfellows
« Reply #3 on: November 10, 2013, 10:53 PM »
Just checked, my tuf / pro necks are all 1/4 inch Allen key NOT 6mm.  Lots of 5/8 and 9/16 nuts as wel........
Offline kalex
« Reply #4 on: November 10, 2013, 10:59 PM »
don't they still use imperial sizes in the USA
Offline Bfellows
« Reply #5 on: November 10, 2013, 11:03 PM »
Yep (bless em!). I've restored a couple of old cars and bikes over the years so assume nothing........ bsf, whitworth, BA, AF.......... Or buy a good adjustable  :LolLolLolLol:
« Reply #6 on: November 10, 2013, 11:08 PM »
Yep, my new school profile seat clamp is some weird size that needs it's own special fooking Allen key  ::)
« Reply #7 on: November 11, 2013, 09:49 PM »
Anyone else know a size for sure?  :)
Offline Bfellows
« Reply #8 on: November 11, 2013, 09:57 PM »
Allen bolts in my TNT clamp are 3/16........
Offline kalex
« Reply #9 on: November 11, 2013, 10:45 PM »
i bought a std set of imperial allen keys then you know your covered
« Reply #10 on: November 11, 2013, 10:49 PM »
What about Dia compe caliper nuts, cones, rears etc?
Offline Bfellows
« Reply #11 on: November 11, 2013, 10:54 PM »
As a general rule, most Japanese nuts and bolts will be metric...... JIS (Japanese industrial standard)
« Reply #12 on: November 11, 2013, 10:57 PM »
Cheers Bert, bloody would be woudn't they  ::) Trying to narrow down the most common nut and allen sizes to just 3 or 4 for an little stocking filler i have in mind  ;)
Offline Bfellows
« Reply #13 on: November 11, 2013, 11:13 PM »
Remind me and I'll have 5 minutes tomorrow and post a few of the more common sizes....... Tuff pads, stem bolts, flange nuts and the like  ;)
« Reply #14 on: November 11, 2013, 11:18 PM »
Nice one Bert  :4_17_5:
If i get round to what i'm planning you just earnt a free one  :daumenhoch:
Offline Bfellows
« Reply #15 on: November 12, 2013, 04:04 PM »
Here goes........ just remember that there is no guarantee that someone has not swapped out nuts and bolts over the years for new.
As a general rule, Japanese and French = Metric, American = Imperial........ unless its US, but made in far east such as Haro stems etc and also a lot of the later US stuff seems to have now gone metric.  If its British - could be anything.......
These sizes are in the main taken from OG items.
Stem top bolts (all allen key) - Suntour = 6mm, Haro Group 1 = 6mm, Tuf / Pro neck etc = 1/4", Torker 6 bolt = 3/16".
Chain ring bolts = Sugino = 5mm allen key
Headset nuts = Everything I have is either 30 or 32mm
Seat clamps = All my Japanese made are 6mm, American 1/4 and 3/16" allen key
Wheel nuts - Generally 15mm, but my new tuffs have 14mm.......
Seat guts - Elina lightning bolt = 14mm, Dominator = 13mm, Kashimax - both 13mm and 14mm KSM stamped
Tuff pads - old style 10mm nut, new style 5mm allen key
Dia Compe brakes - Acorn and rear nyloc nuts are 10mm, larger locking nut on 901s is 13mm, cable clamp acorn nut is 8mm.  Most of the adjuster screws on levers are Phillips head
Pedals - everything I have is 15mm, but some requires a slim spanner
If you need anymore i'll have a dig through the cave.
Bert
Offline Devilock
« Reply #16 on: November 12, 2013, 05:00 PM »
Bloody hell what a thoroughly blokey thread!
Offline Bfellows
« Reply #17 on: November 12, 2013, 05:09 PM »
Thank you........ ;D a misspent youth of skinless knuckles made me at the age of 40 finally take my old mans advice and use the correct size spanner for the job.
« Reply #18 on: November 12, 2013, 05:11 PM »
Bert you are a fookin legend mate, nice one  :4_17_5:
