976236 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 02, 2026, 07:58 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  spider sizes
Author Topic: spider sizes  (Read 2032 times)
spider sizes
« on: November 27, 2013, 10:19 PM »
looking at buying a spider but its listed in 2 sizes...
sizes 15/16” – 23.8mm and 3/4" - 19mm Spindle Hole.
whats the old/early mid standard? I'm guessing 19mm  :daumenhoch:
Offline fischflo
Re: spider sizes
« Reply #1 on: November 27, 2013, 10:25 PM »
Recently read thata "standard 1piece crank is 23.8mm"; so i'd say 23.9mm is the standard ---- if i'm wrong, blame Brett :D
Re: spider sizes
« Reply #2 on: November 27, 2013, 10:29 PM »
sorry ... should have said this is for a 3pc crank
Offline fischflo
Re: spider sizes
« Reply #3 on: November 27, 2013, 11:19 PM »
since most 3pc/race cranks' spindles seem to be 19mm, you should be (al)right with a 19mm bored spider
Re: spider sizes
« Reply #4 on: November 28, 2013, 07:22 AM »
Cheers Fischyman  :slayer:
Offline VOIVOD
Re: spider sizes
« Reply #5 on: November 28, 2013, 12:35 PM »
 :) Think most spiders had a 23.8 mm hole that fitted straight onto 1 pc cranks and older square taper axle 3 pc cranks.You can then add a tophat washer to fit to  either a 19 mm or 22 mm crank spindle.
Re: spider sizes
« Reply #6 on: November 29, 2013, 09:56 AM »
thanks James ... hope all is good with you mate  :smitten:
