976236 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 02, 2026, 06:57 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Bottom bracket boot:
Author Topic: Bottom bracket boot:  (Read 1879 times)
Offline rockinwookie
    • Variantmusic
« on: November 30, 2013, 05:44 PM »
Im sure there was a way we used to stop Bottom Bracket boots moving years ago but cant remember now....
My Bb boot is spinning around when i pedal, any ideas guys?
Re: Bottom bracket boot:
« Reply #1 on: November 30, 2013, 05:48 PM »
double sided tape perhaps  :-\
Offline steve69
  • aka. Steve Changa
« Reply #2 on: November 30, 2013, 06:01 PM »
Didn't we used to put them in boiling water to soften them, then fit it and it would shrink into place when it cooled down.  :-\
(Could be talkin shite)
« Reply #3 on: November 30, 2013, 07:14 PM »
That's just how you're supposed to fit them innit
    • Variantmusic
« Reply #4 on: December 02, 2013, 12:43 AM »
Awesome, Cheers for the thoughts guys will try :D
Online CustardLips
« Reply #5 on: December 02, 2013, 01:12 AM »
Wrap a cable tie round it. :daumenhoch:
It'll look shit but it'll work.   :D
"WWG1WGA"
rodriguez
« Reply #6 on: December 02, 2013, 12:42 PM »
I've some different coloured cable ties I could send you a couple.
What colour is the boot?
Offline steve69
  • aka. Steve Changa
« Reply #7 on: December 03, 2013, 06:42 AM »
Is it because your centre hole for the spindle/crank needs enlarging slightly ???
    • Variantmusic
« Reply #8 on: December 06, 2013, 12:20 AM »
didn't think about the centre hole thing and havent tried hot water either.
I dont think ill go down the cable tie route but thanks for the offer :)
« Reply #9 on: December 06, 2013, 01:52 PM »
I think you might have to
If you already fitted the boot (without softening it first) then you may have stretched it too much to begin with
You may be lucky with the hot water, but if it's still too baggy at least the ties should keep the cack out
The centre hole should be as tight as Peter J the day before pay day
« Reply #10 on: December 06, 2013, 08:40 PM »
+1  :)
Offline Andy68
« Reply #11 on: December 06, 2013, 09:20 PM »
My crude technique..... glue the fooker on!!!  :LolLolLolLol:
    • Variantmusic
« Reply #12 on: December 07, 2013, 12:03 AM »
Cheers again guys :D
