976236 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 02, 2026, 06:57 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  probably a dumb pedal question
Author Topic: probably a dumb pedal question  (Read 1759 times)
« on: December 05, 2013, 08:59 PM »
trying to screw some crupi peds into Profile crank arms... they go on fine 'the wrong way round' ... so they unscrew when you pedal ... but they will not screw on the right way round .....  :idiot2: just won't screw into the threads ....
The profile are on the right sides... can't work it out  :buck2:
Re: probably a dumb pedal question
« Reply #1 on: December 05, 2013, 09:03 PM »
Crank arms back to front? ???
« Reply #2 on: December 05, 2013, 09:08 PM »
nope - arm that screws onto the chainwheel is on the right.
so the pedals screw on the wrong sides so the logos on the pedals face the wrong way  :teef:
Offline Munnyella
« Reply #3 on: December 05, 2013, 09:10 PM »
Perhaps the pedal spindles were swapped over when they were run on a set of RHD cranks, used as left hand drive set up.
m
« Reply #4 on: December 05, 2013, 09:12 PM »
This /\ /\ /\ /\ was just typing it and pipped to the post
« Reply #5 on: December 05, 2013, 09:15 PM »
m
cheers Mark ... you doing owt?  :popcorn:
Offline Munnyella
« Reply #6 on: December 05, 2013, 09:17 PM »
m
Drinking lager, ignoring twats on the telly.
« Reply #7 on: December 05, 2013, 09:57 PM »
think you nailed it there Marky lad - cheers bud  :daumenhoch:
