976236 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 29, 2026, 04:55 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Yes sir, i can resto - SHIMANO DX cha cha cha
Author Topic: Yes sir, i can resto - SHIMANO DX cha cha cha  (Read 9611 times)
Offline fischflo
« on: December 11, 2013, 01:14 AM »
Plan: ... wanna make these shiny   ......strip strip, polish shiny --- girly route with the thinner strip
Problem nr 1: the fookin end caps.
Got new one, so could smash em in, but i got them out ....using a small flat screw driver à la Bigplinky or Minihaha. - The screwdriver is not ideal, cause it will pop through the plastic and leave a little hole - but that'll be in one of the 2 indentations, so no big deal i find. Better tool could be used, but i'm hectic
Trick is to rather turn the cap around rather than try to pop it out. After a few (...) turns one side of the cap will stick out a bit, and then you lever the thing up.
Worked fine with the 1st pedal. The second cap was stuck however --- so i searched and found this trick -forgot who said it :-X-, but you just pop the pedal in the oven for 10 minutes and then you can probably get the turns done.
Offline fischflo
Re: Yes sir, i can resto - SHIMANO DX cha cha cha
« Reply #1 on: December 11, 2013, 01:41 AM »
Step2: ...get the axles/spindles out.
This is what you see
There are two nuts to be removed. For the first you need  two wrenches ... one 11 and one 15 mm wide i think it was.
You tighten the 11 to the table, place the pedal over it, and then you twist the spindle off. Easy ::)
The "probem" is the second nut. It's to far down for a wrench, so you probably need a special tool. I however just used a blade sort of thing, with the right size to fit between the larger nut and the inside of the pedal. basically used in the same manner i used the 11 mm wrench - it holds the nut in place while i screw off the spindle.
Offline fischflo
« Reply #2 on: December 11, 2013, 01:53 AM »
...hello bearings :teef:
...and hello you bearings, too
i beg you: ... someone said it: place the pedals over something tray-like before you pull the spindles out.
I didn't, heard a thump; and spent 20 minutes looking for the missing bearing ball
Step 3: .... after removing the balls and the gunk, place em in a small container and spilll thinner all over em and leave em in there for caouple of days .... like i read here ->http://www.radbmx.co.uk/forum/index.php/topic,166319.msg1664256/topicseen.html#msg1664256. Cheers meticulous
...lets see if it wörks :D
« Reply #3 on: December 11, 2013, 02:37 PM »
I used a socket spanner on the nut inside the pedal Fishy  :daumenhoch:
Offline thebigdog
« Reply #4 on: December 11, 2013, 02:56 PM »
Going to say never had an issue with socket.
« Reply #5 on: December 11, 2013, 03:00 PM »
got any hints for pin resto ... got some GT DXs that need missing pins replacing  :daumenhoch:
Offline Gnarlyscoots
  • BANNED
« Reply #6 on: December 11, 2013, 03:23 PM »
Get down the iron mongers Ed and get a steel rod the same size. Cut to length and tap in...voila!
BANNED
« Reply #7 on: December 11, 2013, 04:03 PM »
lots of info in here
http://www.vintagebmx.com/community/index.php'showtopic=4005471&st=95
dowel pins!
or I've read on here people have used welding rod or cut down rivets..
If anyone gets some dowel pins in I could do with 3 of them, can't be arsed to order hundreds :teef:
"Machinists know them as "Dowel Pins". That is your Internet buzz word.
MSC (and many others) has any size you want. In this case they are 1/8 inch and .375" long. The smaller ones are 3/32" by .375"long. You can do as I did and use black oxided pins for the main pins, and shiny for the cast pins, or whatever you like. These pins are usually grade 8 or better, and hardened. They will last through many pairs of shoes."
« Last Edit: December 11, 2013, 04:05 PM by griff »
Offline chubby
  • Needs Pegs
« Reply #8 on: December 11, 2013, 06:09 PM »
Couple of days !!!!!!!!
Oven pride 5 mins job done & some nice red marks on your hands to show the mrs how clever you are  :LolLolLolLol:
Don't use it on that ppp disc though  :2gunsfiring_v1:  :LolLolLolLol:
Offline Sheikh Yerbouti
« Reply #9 on: December 11, 2013, 06:18 PM »
Oven pride doesn't work on paint  ::)
Just anodise
DX were never anodised  :)
Offline chubby
  • Needs Pegs
« Reply #10 on: December 11, 2013, 06:41 PM »
Just anodise
DOH !!!!!!!!!!!!
forgot about that mr yerbouti   :-[
Stripped my gold ones a treat though.....
« Reply #11 on: December 11, 2013, 09:48 PM »
Here you can get a hundred delivered for about £20
http://www.boneham.co.uk/shop/product/imperial_stainless_steel_dowel_pins
Maybe there's a radster somewhere lives close enough to pick up a few...
Offline fischflo
« Reply #12 on: December 11, 2013, 11:18 PM »
 .......... so some colours are painted and some are anno'ed i take :D ???
A) for anno'ed ones  (gold, ...?): Oven pride
B) for the painted  (black, ...?): nitromors, thinner, or .... synstrip
Yep, anything like that. It comes off really easy :daumenhoch:
I think I used Rustins Strypit.
-> http://www.radbmx.co.uk/forum/index.php/topic,131361.msg1359639.html#msg1359639
i guess that Synstrip is bit stronger - i'll try that once i failed with the thinner  :slayer:... cheers Sheikh
Offline oldscool
« Reply #13 on: December 12, 2013, 09:21 AM »
I put my sons dmr v12s in caustic soda didnt seem to be working, left them all day as I forgot and turned them into volcanic rock oops. Turned out to be paint. :10_2_12:
If in doubt flat out.
« Reply #14 on: December 12, 2013, 07:00 PM »
If original finish they r all defo painted  :daumenhoch:
Offline fischflo
« Reply #15 on: December 12, 2013, 11:21 PM »
You hear it, boys ....they're all painted :yahoo_silent:
...just splodged them in 1l turpentine replacement ......lol lets see if that'll doo ...let me see you stripped  :2gunsfiring_v1:
rodriguez
« Reply #16 on: December 13, 2013, 01:54 AM »
Did the thinners not work Flo   :-\
Offline CustardLips
« Reply #17 on: December 13, 2013, 02:56 AM »
Thinners/turps is great for shifting the oil/gunk/shit but stripping the paint ? I'm not so sure.  ???
"WWG1WGA"
Offline Howser
« Reply #18 on: December 13, 2013, 01:54 PM »
I'm interested in seeing how these come out as I've got some to do myself  :daumenhoch:
Offline fischflo
« Reply #19 on: December 13, 2013, 02:03 PM »
well the smell was like thinner's ...and it's all i found in the basement in sufficient amount to cover the pedals with :teef: ...lazyness breeds invention, like my first dealer used to say .... :laugh:
« Reply #20 on: December 13, 2013, 02:30 PM »
next time try tomato ketchup
Offline CustardLips
« Reply #21 on: December 13, 2013, 02:35 PM »
No invention needed fischy. Just buy some fookin paint stripper.   :idiot2:  :LolLolLolLol:
"WWG1WGA"
« Reply #22 on: December 13, 2013, 08:26 PM »
These threads are the best  :daumenhoch: :daumenhoch: :daumenhoch:
Offline fischflo
« Reply #23 on: December 13, 2013, 09:49 PM »
Socket spanner ..of course!  :daumenhoch:
DOH !!!!!!!!!!!!
...might have been spraypainted? Just read the Ovenpride does work on that. (->http://www.vitalbmx.com/forums/General-BMX-Talk,2/paint-stripping-pedals-help,1229508)
..... :( ....after 1 day in the bath, nothing. Maybe it's too cold outside or maybe thinner's different? Whatever, next stop Nitromors/paint stripper
Offline fischflo
« Reply #24 on: December 16, 2013, 07:55 PM »
