976236 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 02, 2026, 03:10 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Shimano DX bearing size
Author Topic: Shimano DX bearing size  (Read 1550 times)
Offline Bfellows
« on: December 11, 2013, 06:01 PM »
Are the bearings 3/32?....... or metric?
Offline Bfellows
Re: Shimano DX bearing size
« Reply #1 on: December 13, 2013, 09:38 PM »
 :bump: anyone?
Offline Howser
« Reply #2 on: December 13, 2013, 09:50 PM »
I took the bearings out of my dx the other week and not put them back yet - I'll see if can measure one up for you over the weekend.
Offline Bfellows
« Reply #3 on: December 13, 2013, 09:52 PM »
Thanks, mine are fooked...... Hard to mic accurately.....
Offline fischflo
« Reply #4 on: December 13, 2013, 09:58 PM »
"Bearing size ar 4mmŲ, 11 per side, u need total 44 per a set pedals
VP550 shape almost the same as SX pedals, They should work out with SX, DX too" ->http://www.ozbmx.com.au/index.php'showtopic=26250
3/32 inch
« Last Edit: December 13, 2013, 10:00 PM by fischflo »
Offline Bfellows
« Reply #5 on: December 13, 2013, 10:02 PM »
I do wish they wouldn't mix metric and imperial.......
Offline rooski
  • Mons Veneris
« Reply #6 on: December 13, 2013, 10:49 PM »
Crank threads are imp sizes,so they need to mix em,the spindle lock nut is m10 fine,all jap stuff is metric usually, but most bike standards are european,Japs must fookin hate it...................
Offline snoopy72
« Reply #7 on: December 15, 2013, 09:36 AM »
You can use 4 mm or 5/32 bearings.
