976236 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 02, 2026, 01:58 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Collar inside MRD Badlander forks
Author Topic: Collar inside MRD Badlander forks  (Read 2799 times)
Offline Bfellows
« on: December 21, 2013, 04:47 PM »
There appears to be a collar of some sort inside the forks on my Badlander that stops the stem from going right into the forks.  Any ideas?  They haven't been repaired and the "collar" seems to be in fairly snugly.  Do I attack it with a large hammer and drift?
Offline john4130
Re: Collar inside MRD Badlander forks
« Reply #1 on: December 21, 2013, 04:51 PM »
looks like a piece of cut up seatpost has been rammed in there, is there anything stopping it from coming out the bottom of the forks? if not, get an old straight seatpost in there and try hammer it out.
« Reply #2 on: December 21, 2013, 05:14 PM »
are you sure these forks havent been repaired  :-\ ..... and repainted/powdered ?
Offline sawzall
« Reply #3 on: December 21, 2013, 06:36 PM »
at a guess i would say they may have had a new steer tube welded
in and a joiner piece has been fitted to strengthen joint :-\
Offline Bfellows
« Reply #4 on: December 21, 2013, 06:39 PM »
Yep, looks to be the case.  I'd never even noticed when I changed the headset out......... plenty of grease ;D  Reckon you can sort them out?  I hate bodges.......
« Reply #5 on: December 21, 2013, 08:36 PM »
Sounds like you need to chuck it in the skip Bert :-\
Just let me know where and when and I'll have it back out in seconds :2funny:
Offline Bfellows
« Reply #6 on: December 22, 2013, 01:14 PM »
 ;D  Its slowly becoming my second nemesis after the TA...........  Its not going to beat me though, just something else to get sorted.  I have a feeling I shall making Phil's acquaintance in the near future.......
« Reply #7 on: December 22, 2013, 01:25 PM »
Bert do you know the internal measurement of the normal steerer tube? I have a drill bit which may do the job. I bought it to ream out the internal taper on a set of forks i wanted to run a linear bearing on for a woody style brake mod.  :daumenhoch:
The forks were 21mm ish at the top but tapered to around 19.5mm where it met the top of the forks  >:(
Offline Bfellows
« Reply #8 on: December 22, 2013, 01:42 PM »
Internal diameter is 21mm.  I'll post a couple of pics when I get chance.
I think that they need breaking apart and re doing correctly as it looks as though they've been badly welded to the sleeve and the welds filed down.  I'd rather they were butt welded properly and then the excess spun down on a lathe or preferably a new steerer tube fitted.  I've not got the gear for doing it myself these days so I think i'll need to box em up and send them to someone who can.......  Noticed a hairline crack on my DP seat post as well so might as well get that sorted at the same time.
  • Andy
« Reply #9 on: December 27, 2013, 10:28 AM »
I sense a trip to the man Phil Sawzall maybe needed. A master if ever there was one
Offline Bfellows
« Reply #10 on: December 27, 2013, 11:30 AM »
Yep, PM already sent to Phil.  Hopefully he can perform minor miracles....... Then off to SBD for new powder.  I'm thinking grey and black........
  • Andy
« Reply #11 on: December 28, 2013, 11:18 PM »
Both Phil and Dan are masters of their trades and top blokes too. They've both done work for me and the quality of their work, and their service is  :4_17_5: I'm sure they will be able to sort it out for you. Good luck Bert.
