Pro Star seatpost 24.8mm... what shim size out of these would I need???
<< < (2/2)
snoopy72:
--- Quote from: Knarly on December 29, 2013, 05:40 PM ---Ah that makes sense now  :LolLolLolLol:
I,ve used the same trick with the seat post shim. I hate knowing that it's in there but like snoopy72 said it is more important to prevent cracking.
--- End quote ---
You need to check this measurement especially if you have a creaking sound when out on a ride
spadey99:
Ok guys but what shim should I buy. .. what size would convert 24.8mm seatpost to 22.2mm  :(
sparky:
--- Quote from: spadey99 on December 29, 2013, 07:32 PM ---Ok guys but what shim should I buy. .. what size would convert 24.8mm seatpost to 22.2mm  :(
--- End quote ---
Since the difference is 2.6mm, that would require a material thickness of 1.3mm
I'm pretty sure I used a 25mm to 22.2mm shim and it worked fine and I've built several Pro-Stars.  :daumenhoch:
http://www.unicycle.uk.com/seatpost-shim-25-0-to-22-2mm.html
spadey99:
Cheers mate  :D
sparky:
--- Quote from: spadey99 on December 30, 2013, 09:54 AM ---Cheers mate  :D
--- End quote ---
You can see some here https://www.facebook.com/groups/OSDBBMX/  :daumenhoch:
Navigation
[0] Message Index
[*] Previous page
Go to full version
