976309 Posts in 138996 Topics by 6434 Members - Latest Member: Darbs July 22, 2026, 02:29 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  1st Gen Bullseye Cranks
Author Topic: 1st Gen Bullseye Cranks  (Read 2865 times)
« on: January 02, 2014, 10:16 PM »
Can someone please tell me when they first became available.
Thanks
Adam
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
Re: 1st Gen Bullseye Cranks
« Reply #1 on: January 03, 2014, 12:58 AM »
Bullseye first released cranks in '74 Adam. Do you have a picture of the ones you're referring to?
Offline Gnarlyscoots
  • BANNED
« Reply #2 on: January 03, 2014, 01:29 AM »
Back in the early days, there were actually 6 or 7 versions of cranks and up to a dozen prototypes:
1st gen  -  V1 19mm spindle    - Side bolt spider mounting, Hollow spindle 1974-1975+
1st gen  -  V2 22.2mm spindle - Side bolt spider mounting, Full hollow spindle, No end cap, No safety washer key. 1976-1977+
1st gen  -  V3 22.2mm spindle - Side bolt spider mounting, welded safety end cap and safety washer. 1979-1980+
2nd gen -  V1 22.2mm Spindle - TA Cyclotourist spider plate mounting. 1981-1985+
2nd gen -  V2 22.2mm Spindle - TA Cyclotourist spider plate mounting. Safety Key washer non drive side. 1985-1990+
3rd gen  -  V1 22.2mm Spindle - 3 piece Hurricane arms, Tapered drive to TA Spider plate. 1992+
All dates are estimates based purely on original mechanical drawings,
documentation & sales figures/receipts coinciding with respective years!
I trust this information will now put you in good stead to know what is what.
And that's from a BULLSEYE Authorized Distributor!
« Last Edit: January 03, 2014, 01:32 AM by Londonhellboy »
BANNED
« Reply #3 on: January 10, 2014, 07:29 AM »
Thank you both. :daumenhoch:
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #4 on: January 10, 2014, 11:17 AM »
I'm fairly certain that the ones you're referring to, as they're most commonly called 1st Gen for BMX are the set introduced in 79-80, they look very similar to those on your Torker Adam but without the TA mounting...
« Reply #5 on: January 11, 2014, 09:26 AM »
That's the ones Chris, I have a set already and wanted to check timelines before fitting them to a frame I have.
