976236 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 02, 2026, 01:39 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Mongoose id.. team 79??
Author Topic: Mongoose id.. team 79??  (Read 2560 times)
Offline spadey99
« on: January 07, 2014, 01:27 PM »
Hi guys
This turned up today and thought was just a 79 goose but the T on serial tells me its a rare none flat chain stay September 79 Team goose??
Anyone clarify as I thought all none flat chain stay ones were 77ish....
sent from my lavatory
Bikes are there to be ridden, so why do I have so many.....
Re: Mongoose id.. team 79??
« Reply #1 on: January 07, 2014, 03:09 PM »
Steve, the only way to be 100% sure on this would to strip it and wiegh it mate. Mongoose used to put the stamp on the BB's before, during and after fabrication so it could be either..... tragically I suspect without the flattend rear stay it's not and they just grabbed a pre-stamped BB when fabbing it up, but you could be lucky :-\
I'll dig out a picture of my '78 Team frame stripped down on the scales for you to check against if it helps bud :daumenhoch:
Offline spadey99
« Reply #2 on: January 07, 2014, 03:14 PM »
Cheers spen no drama just wondered. ...
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #3 on: January 07, 2014, 03:48 PM »
Very nice all the same.  Kap has one with flattened rear stays.
Offline snoopy72
« Reply #4 on: January 07, 2014, 06:21 PM »
Hi, they did make some team frames without the flat stay, a motomag rear stay tubing has a 1.9mm wall thickness and a team frame is around 1.4mm, you can measure this at the rear drop out area with a digital vernier
« Last Edit: January 07, 2014, 06:29 PM by snoppy72 »
Offline spadey99
« Reply #5 on: January 07, 2014, 06:32 PM »
Cheers mate will do tonight....
Offline spadey99
« Reply #6 on: January 07, 2014, 07:50 PM »
Measured and I reckon bout 1.45mm or bit more but defo not 1.9mm
Offline spadey99
« Reply #7 on: January 07, 2014, 09:08 PM »
Come up well with quik peek as well
Offline snoopy72
« Reply #8 on: January 11, 2014, 09:35 AM »
The frame is a super  :daumenhoch: If it was a team it would have come standard with team forks.
  I think it's a sep 79 nickel supergoose, supers were nickel upto about June 80 then they were a frosty chrome, in about June 81 when they changed to the later rear drop outs and were show chrome.
I'm not sure on the forks though,  I know that early 77-79 supers had tange pinch forks but it seems a little late not to have team forks but it has no flat chain stay either so they could be correct.
A nice find  :daumenhoch:
« Last Edit: January 11, 2014, 10:11 AM by snoppy72 »
Offline spadey99
« Reply #9 on: January 11, 2014, 09:50 AM »
Hi mate
Will have a look later but dont think coaster tab has been cut off. .. will check serial on forks  :daumenhoch:
Offline snoopy72
« Reply #10 on: January 11, 2014, 10:06 AM »
Hi mate
No sorry for some silly reason I thought it was March 79 :idiot2:, Sep 79 had no coaster tab so that's correct.
The forks may be close to the date of the frame but may not be the same month as they were probably lying around and the first set picked up when a frame was built.
If the forks are a different year they were probably not matched with the frame, this code can be hard to read though .
« Last Edit: January 11, 2014, 10:08 AM by snoppy72 »
Offline spadey99
« Reply #11 on: January 11, 2014, 10:08 AM »
Sweet... checking now bud... great info. Thanks
Offline kalex
« Reply #12 on: January 11, 2014, 01:18 PM »
They look like regular motomag pinch forks
Super and team goose had the same style dropouts as forks on early cali's, expert's etc.
