976236 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 02, 2026, 01:39 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Has my peek past it's peak ????
Author Topic: Has my peek past it's peak ????  (Read 2049 times)
Offline chubby
  • Needs Pegs
« on: January 09, 2014, 05:44 PM »
Hiya fellas, been rubbing away at a frame today only got slight surface rust here n there & mainly around the welds. Soaked in wd40 overnight & found my tin of peek given it a good stir up & it doesn't seem to be working like it used to !!!!!
Can peek "go off" the tins about 18 months old ????
sent by me !!!!!
rodriguez
Re: Has my peek past it's peak ????
« Reply #1 on: January 09, 2014, 07:22 PM »
You might just need to use something a bit more effective on the rust like oxalic or citric acid or even some lemon juice or vinegar with a bit of aluminium foil.
Offline chubby
  • Needs Pegs
« Reply #2 on: January 09, 2014, 08:05 PM »
Thanks Rodriguez, although the rust is minimal it might be clinging on for dear life  :LolLolLolLol:
I'll have a go with the oa first bud  :daumenhoch:
Offline spadey99
« Reply #3 on: January 09, 2014, 09:20 PM »
Yo Rich..... I have sworn by this stuff on any chrome, nickle frame to remove rust and grime and its never let me down..... apply... leave for 2 hours and soft greeny sponge type scourer and it eats rust......
http://prorust.com/information/product-range/#!prettyPhoto
Gel stuff is best....
Beats Oxi bath mate... just used it on nickle goose.... if you want pics PM me....  :daumenhoch:
Bikes are there to be ridden, so why do I have so many.....
Offline chubby
  • Needs Pegs
« Reply #4 on: January 09, 2014, 10:26 PM »
Cheers steve, looks some good $ hit dude  :daumenhoch:
Can't find the fookin oa anyway so gotta by something  "nono"
Offline chubby
  • Needs Pegs
« Reply #5 on: January 10, 2014, 05:16 PM »
Found some autosol at work which must be 15 years old & it's worked a treat ???
Is my peek dead !!!
rodriguez
« Reply #6 on: January 10, 2014, 05:32 PM »
Is my peek dead !!!
Autosol may be a diiferent chemical make up and is more abrasive so will remove some rust.
Peeks crap for rust removal should still polish OK though, try some on a bit of alloy if the cloth goes black and it shines your peek is fine.
Shouldn't go off.
Offline chubby
  • Needs Pegs
« Reply #7 on: January 10, 2014, 05:39 PM »
Once I'd got the rust off I gave it a peeking & it's really come up  :)
Like you say the rust must of been too tough for peek alone
Thanks for the advice  :daumenhoch:
