976236 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 01, 2026, 05:47 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Spoke lengths: Suzue LF to 7X
Author Topic: Spoke lengths: Suzue LF to 7X  (Read 2166 times)
Offline 20to26
« on: January 28, 2014, 05:45 PM »
What spoke length do I need to lace Suzue low flange sealed hubs to Araya 7X rims please fellas?
Re: Spoke lengths: Suzue LF to 7X
« Reply #1 on: January 28, 2014, 05:46 PM »
194 mm 4 cross  pattern Steve   :)
« Reply #2 on: January 28, 2014, 05:47 PM »
194mm 4 cross :daumenhoch:
Offline 20to26
« Reply #3 on: January 28, 2014, 05:48 PM »
Thanks dudes!
Offline 20to26
« Reply #4 on: January 30, 2014, 03:18 PM »
Another question - how does 4x differ from the 3x in the wheel building thread? ???
Offline That Swan Guy
« Reply #6 on: January 30, 2014, 05:18 PM »
You pass your leading spokes over 4 trailing spokes  as opposed to 3  till it goes in the desired hole   :)
« Last Edit: January 30, 2014, 07:25 PM by hunterdubber »
« Reply #7 on: January 30, 2014, 06:04 PM »
You pass your trailing spokes over 4 leading spokes  as opposed to 3  till it goes in the desired hole   :)
Don't you mean 'under' dubber  ???
4 cross   ........ under 3 over 1
3 cross ....... under 2 over 1
first set of spokes are inserted the same for both 3 and 4 cross  ;)
« Reply #8 on: January 30, 2014, 07:41 PM »
 ??? Do I   :D
I always thought the second set of spokes  (the  crossing ones  :D) you lace to a rim ,were crossed over 3 then under on the last one to find the hole  ???,,oooer  ^"^  :LolLolLolLol:
Has it been mentioned before  some lad called Sean on here has wrote a thread  about wheels  and spokerizing :LolLolLolLol:
