BMX General > BMX Chat
Get rid of those ugly cable ties and bits of velcro. PICS ADDED
<< < (2/2)
GavinDavis:
Top little product  :daumenhoch:
Jono:
http://www.ebay.co.uk/itm/131101873154
i got a pile of these off the bay they are perfect
oldtired:
good idea  :daumenhoch: like the t's too,
you can use a giro tab on the top of the down tube  or under the top tube just behind the headtube with a slight angle depending which side you run the cable , dead easy to drill n tap the tube 4mm (may void your warranty ;D)  been going to do mine but velcro is easier  :D  tbh i don't know why companies don't bung one on the frame near the headtube , wouldn't be in the way if you ran a giro and would save nicking the laggy out yer wangers to tie the cable up if you run a single   ;D  course they'd be useless on a brakeless frame  :LolLolLolLol:
rodriguez:
BITD we used insulation tape only the posh kids had cable ties   :pilky:
oldtired:
remember the local bmx shop had some reusable zip ties would have been about 83ish , never seen a zip tie before, different colours but they were £1 each , the general opinion was leccy tape is £0.12p a roll from franks shop at the end of the road  :LolLolLolLol:
Navigation
[0] Message Index
[*] Previous page
Go to full version
