976309 Posts in 138996 Topics by 6434 Members - Latest Member: Darbs July 18, 2026, 10:41 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Landing gear, is there a definitive way to id unstamped forks?
Author Topic: Landing gear, is there a definitive way to id unstamped forks?  (Read 2245 times)
Ive got a set of landing gear lookalikes, that have come on an 84 kuwi frame.
I say lookalike, they are unstamped, and the holes on the drops are nor quite in line.
Have we decide on a definitive answer on id'ing early lg's?
I know that se haulers had non us gear, stamped with lung, or lang, and of course the lites were thinner.
Any ideas on specifics?
Also, what were the "max" forks like?
Bob? Rich?
Re: Landing gear, is there a definitive way to id unstamped forks?
« Reply #1 on: February 14, 2014, 10:00 AM »
Yes there is and I'll try and answer later when I'm on the comp. There's a good timeline thread on the museum which will also help you.
Offline Waxintaxin
« Reply #2 on: February 14, 2014, 12:56 PM »
PHOTO YOUNG PHIL
you can tell with welding points and holes etc
Offline fischflo
« Reply #3 on: February 14, 2014, 01:09 PM »
« Reply #4 on: February 14, 2014, 04:18 PM »
PHOTO YOUNG PHIL
the holes are very slightly staggered, ie centres not in a direct line. weld points are obv a photo needed job, i realise.
ive not got a camera to take a photo, mine got pissed wet through the other day so its on the shopping list.
« Reply #5 on: February 14, 2014, 04:26 PM »
there is no 'fourth hole' on the dropouts - a small washer-tab retention hole next to the axle signifies a copy
it doesnt have this hole.
also there is no gas release hole, at least non visable, theyve been painted badly as has the frame, several times. should the gas holes be at the bottom of the legs on unstamped lg's?
apparently bmx museum says a continuous weld on the outside, and three on the inner? does that hold true for yours rich?
Offline fischflo
« Reply #6 on: February 14, 2014, 05:53 PM »
..wtf are gas holes for...? :laugh:
« Reply #7 on: February 14, 2014, 06:25 PM »
Little holes normally at base of forks. Something to do with the manufactoring process. Most forks have them.  :)
Offline fischflo
« Reply #8 on: February 14, 2014, 06:42 PM »
ah cheers, probably to blow shavings out or smth :daumenhoch:
here's a pic of the gas holes , drop holes and the welds on unstamped lg
->http://bmxmuseum.com/forums/viewtopic.php?id=568251
..so lets see if Rich's got the same welding on his             (sorry brief hijack phil)
Offline Waxintaxin
« Reply #9 on: February 14, 2014, 10:57 PM »
Yep
All my holed landing gear are exactly like those
3 inner welds , continuous outer
Tidy welds
Gas holes at the bottom
« Reply #10 on: February 16, 2014, 09:15 AM »
gas hole are to release the build up of pressure in the tubes caused through heat in the welding process, without small holes the tubes would be airtight.
« Reply #11 on: February 16, 2014, 09:18 AM »
Thanks guys, ill post a pic up as soon as i get my camera sorted. The only thing that lead me to be suspicious, is the misalignment on the "weight saving" holes on the dropouts.
Offline fischflo
« Reply #12 on: February 16, 2014, 11:41 AM »
thx obe 8)...at last i know. Originally thought they were weep holes, for weeping!
« Reply #13 on: February 21, 2014, 07:57 AM »
well, they are, if like me, you decide to drunkenly ride your haro master in the sea, and the salt water makes it rust from the inside out, leavy rusty stains around the hole no matter how much you rinse it.... :idiot2:
