Subsitute VDC Forks
<< < (2/2)
Galaxy_Nine:
I have some Wal Roit forks look mush like the bottema's
dancetothedrummersbeat:
In an interview with Voris Dixon, he said that he copied the design from Robinson forks. Can't remember if he used to make Robinson stuff bitd. You'd need to get the steerer tube extended though to take the 5 inch headtube.
glenboy:
I never knew they had a 5 inch head tube cuts your choice a bit , redline pro line pl20 forks are for 5 inch headtube
steve69:
The headtube on a Changa is 4-5/8" so you'll want a fork steertube around 6"
As Glen said your options are slim, Redline Proline sound feasible or possibly Champion  :-\
How about getting Voris to repop a set for you, gotta be a better option then 'cut n shut'
have you got a frame? Or you gonna have a pop at Ray's 83  ^"^ (wouldn't mind that myself)
MartyC:
--- Quote from: dancetothedrummersbeat on February 18, 2014, 11:17 PM ---In an interview with Voris Dixon, he said that he copied the design from Robinson forks. Can't remember if he used to make Robinson stuff bitd. You'd need to get the steerer tube extended though to take the 5 inch headtube.
--- End quote ---
Robinson were made by Trackmaster.
Navigation
[0] Message Index
[*] Previous page
Go to full version
