976235 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 01, 2026, 06:25 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  bolts for alloy tuffs.. rear size and where from??
Author Topic: bolts for alloy tuffs.. rear size and where from??  (Read 1698 times)
Offline spadey99
« on: February 25, 2014, 10:26 AM »
Guys I need some bolts to replace a hub on a rear alloy tuff. . What size length etc do I need and anyone got any links??
Steve  :daumenhoch:
Bikes are there to be ridden, so why do I have so many.....
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
Re: bolts for alloy tuffs.. rear size and where from??
« Reply #1 on: February 25, 2014, 11:12 AM »
Here you go Steve. Just don't spend all your time drooling over the 1st Gens...  :smitten:
http://mauricemeyer.net/cgi/mm.pl?datafile=../general/BMX.txt&page=BMX/Colored_Graphite_Tuffs
Actually, come to think of it - is bolt length in that article?  :-[
« Last Edit: February 25, 2014, 11:18 AM by Jaan »
Offline spadey99
« Reply #2 on: February 25, 2014, 11:44 AM »
Cheers chris will have a read later  :daumenhoch:
Offline Howser
« Reply #3 on: February 25, 2014, 07:01 PM »
Didn't bendycat have a thread on this and does axle replacements kits?  Worth dropping him a pm to see if he can help out.
Offline spadey99
« Reply #4 on: February 25, 2014, 08:35 PM »
cheers mate, I think Bendy did the spindles... got some off him....  :daumenhoch:
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #5 on: February 25, 2014, 08:41 PM »
You can still pick up Skyway hub replacement kits Steve but thats probably a more expensive way of fixing them.  Can't you measure the original rivets...?
Offline Bfellows
« Reply #6 on: February 25, 2014, 09:09 PM »
You're in luck - they are 4.2mm x 64.43 which makes me think they are most likely imperial........ 5/32 x 2 and 17/32...... Or just buy 4 x 65mm and be done with it. Ere to help...... ;D
Offline spadey99
« Reply #7 on: February 25, 2014, 09:28 PM »
Bert I love you bro  :LolLolLolLol: :LolLolLolLol: :smitten: so what would I search on e bay????? Im useless fellas....  ::)
Offline Bfellows
« Reply #8 on: February 25, 2014, 09:40 PM »
Search for M4 pan head bolts - if memory serves, you can't get 65mm, so get 70mm and trim down.  You need pan heads so the chain clears them when fitted.
Offline spadey99
« Reply #9 on: February 25, 2014, 09:51 PM »
cant find em on e bay... only 60mm length......  >:(
Offline Bfellows
« Reply #10 on: February 25, 2014, 09:59 PM »
« Last Edit: February 26, 2014, 07:46 AM by Bfellows »
Offline Bfellows
