976235 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 30, 2026, 11:27 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Bottom Bracket Probs!!!
Author Topic: Bottom Bracket Probs!!!  (Read 1662 times)
Offline hokuspokus74
« on: March 10, 2014, 06:57 PM »
I am trying to put the bearing cups into a skyway streetbeat,ihave tried a few different sets,and have been battering at it and greased them all but they wont go in,is there a certain opc cup thats needed for the streetbeat?...or how do you get them back in???
Re: Bottom Bracket Probs!!!
« Reply #1 on: March 10, 2014, 07:01 PM »
Has your Beat had fresh powder or paint?  ???
There may be a build up on the inside of the BB, this will need to be sanded down or use a Dremel to make it easier.  :daumenhoch:
What type of BB you using? I had a Tange on mine, it was fine.
Offline stevesredvxr
« Reply #2 on: March 10, 2014, 07:10 PM »
What dan said.
I've had to do it with all my beats. Just get a dremel and take the powder off from inside the bb.
Even take a minute skim from the bb itself, grease it up and knock it in with a rubber hammer or use some threaded rod with bolts either side and some blocks and tighten.....it should then go in.
Steve.
« Reply #3 on: March 10, 2014, 07:20 PM »
What dan said.
Steve.
Every bike I've built, I've banged the cups in no probs, but with my orange Beat I decided to use a press to put them in to protect Dan's amazing paint job, and guess what, the paint cracked.  ::)
« Reply #4 on: March 10, 2014, 07:57 PM »
ok i'll go and remove some paint of it,ive a tange one somewhere but am stumped if i can find it,let yous know how it goes,might need another beat by the time am finished with it :D
« Reply #5 on: March 10, 2014, 07:59 PM »
Never had an issue with any of mine  ???
« Reply #6 on: March 10, 2014, 08:41 PM »
I've always used a long bolt. I put a drilled out block of wood at either end and tighten.  :daumenhoch:
« Reply #7 on: March 10, 2014, 10:30 PM »
SORTED... thank god still had to bash it in though and that was after i used the dremel and grinded a bit of the cups,bloody things :2funny: ...i must remember the other ideas you mention aswell :D
« Reply #8 on: March 20, 2014, 04:20 PM »
thats the best method. you can lock the cups in the bb shell if you get them at a slight angle, and theyll go no further. with the par you can place them flush before tightening.
« Reply #9 on: March 20, 2014, 05:50 PM »
cheers marc oberon  :2funny: i seen him a few time excellent when i was back in my younger day of my rocker on microdots  "wantit"
fook they were good old days :LolLolLolLol:
