976305 Posts in 138996 Topics by 6434 Members - Latest Member: Darbs July 16, 2026, 06:58 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  sugino 400's
Author Topic: sugino 400's  (Read 1323 times)
Offline Jono
sugino 400's
« on: March 24, 2014, 04:20 PM »
tryin to fit them to my changa build are there different length axels as it wont go on the arms need to go on a certain amount to stop latteral movement but when they are on they are catching on the stays on both sides when i adjust them outwards with spacers they then dont fit snug enough making the arms loose is it me or is there as i said a slightly longer axel that will make it fit the changa
axel length is 130mm needs to be longer maybe 140 would do it?
think axel is wrong maybe someone knows its a tange stamped cv 170 cr-mo 83 -j
« Last Edit: March 24, 2014, 05:16 PM by Jono »
Jono
Offline john4130
Re: sugino 400's
« Reply #1 on: March 24, 2014, 06:28 PM »
the 400 axle is a slightly larger diameter to normal square taper axles, so you will have problems finding a longer one if they actually exist. it took me about 6 months to find an axle for my 400s. you could use the spacers to stop the crank hitting the chainstays then use a coke tin to make some shims so the cranks will tighten onto the taper. this was my method i used before i found the correct axle and was using a generic square taper axle, it worked fine.
Offline Jono
Re: sugino 400's
« Reply #2 on: March 24, 2014, 06:37 PM »
 :4_17_5: great idea thats exactly what i'd have done when i was 15 but it still doesnt solve my changa problem wanted high end cranks for it and these the only ones i got  :'(
Jono
Offline antiquebmx
Re: sugino 400's
« Reply #3 on: March 26, 2014, 07:41 AM »
I've got 400s on my changa so kno it should work I thought the spindle was sugino stamped though been years since fitting em
Re: sugino 400's
« Reply #4 on: March 26, 2014, 10:18 AM »
Try Joe6187 I think he was doing some repro axles for these  :daumenhoch:
Offline Waxintaxin
Re: sugino 400's
« Reply #5 on: March 26, 2014, 12:46 PM »
sounds like you have the wrong axle , do the cranks fit tight on the taper off the frame/
Offline Devilock
Re: sugino 400's
« Reply #6 on: March 26, 2014, 01:01 PM »
Indeed...if it's the correct 400 axle it should be fine...
Offline Jono
Re: sugino 400's
« Reply #7 on: March 26, 2014, 07:14 PM »
Right maybe wrong axel they ill pm him see if he got any repros then cheers worth a shot
Jono
