976235 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 30, 2026, 07:23 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Lacing a 36sp wheel
Author Topic: Lacing a 36sp wheel  (Read 1507 times)
Offline snoopy72
Lacing a 36sp wheel
« on: March 29, 2014, 07:59 AM »
Hi, I'm going to re lace a 36 spoke wheel into another rim because it's damaged, I plan on copying the front wheel, I can't get my head around the fact that the spokes bend over each other and cross under the next spoke making it look like a wicker basket  :LolLolLolLol: instead of being nice and straight , why is it like this on a bicycle rim ?  has anyone tried to lace it the other way and come across a problem ?
In the picture below it just looks messy to me, this is not my wheel just a pretty bad example of one.
If you try to remove the spoke between the letters A and I , you would have to remove the spoke between U  and K first to get it out.
Surely if you laced the spokes the other way around they would also be straight
« Last Edit: March 29, 2014, 11:46 AM by snoopy72 »
Offline That Swan Guy
Re: Lacing a wheel
« Reply #1 on: March 29, 2014, 08:01 AM »
Don't think, trust :LolLolLolLol:
Offline snoopy72
Re: Lacing a 36sp wheel
« Reply #2 on: March 29, 2014, 09:05 AM »
This lacing looks much better
Offline Devilock
« Reply #3 on: March 29, 2014, 09:17 AM »
What the feck are you talking about? !
Lace it in the correct way, tighten, true & it will be fine.
If it isn't then you've done it wrong & Sean will visit with a chainsaw.
« Reply #4 on: March 29, 2014, 09:35 AM »
That lacing on the white wheel is what is known as race lace, all the spoke heads are on the inside of the hub, that is a very specialist way of lacing a wheel.
The usual way is for half the spokes to be laced so the heads are on the inside and half on the outside, that way you don't have so much undulation of the spokes.
Offline snoopy72
« Reply #5 on: March 29, 2014, 11:36 AM »
Thanks for the reply stidds  :daumenhoch:
 The wheels are using small flange suzue hubs if that makes any difference to the lacing method.
 I've only just noticed that the heads of the spokes are all on the inside of the white wheel, the wheel i have is inbetween the blue and the white , this is the actual wheel below.
The Z rim has a flat in it at the 8 O'clock position were it looks like it's hit a kerb at sometime , i have another Z rim to replace it.
I can tru the rim no problem
« Last Edit: March 29, 2014, 12:30 PM by snoopy72 »
Offline snoopy72
« Reply #6 on: March 30, 2014, 09:07 AM »
I'm going to go with the original lacing pictured above, am I right in saying that i will need lace all the spokes to the hub then drop the wheel rim over it to put he nipples in ?
 Building the wheels like the blue rims is easy, I can drop the spokes in the hub and lace one spoke at a time to the rim .
« Last Edit: March 30, 2014, 09:16 AM by snoopy72 »
Offline Munnyella
« Reply #7 on: March 31, 2014, 09:48 PM »
easy way if doing a straight swap is put tape on all the spoke cross overs, undo the nips, jiggle it out of the rim, the jiggle it into the new one.
or do it properly, its dead easy.
MM
Offline snoopy72
« Reply #8 on: April 01, 2014, 06:11 PM »
Thanks, I may well try that :daumenhoch:
Offline kev-s
« Reply #9 on: April 02, 2014, 08:30 AM »
MM
yep this makes rim changes so much easier!!!
good tip given by mirra back in 92 in the ride on vid :daumenhoch: :daumenhoch:
