976235
ludwig242
April 30, 2026, 10:43 AM
Stem Restoration
Topic: Stem Restoration (Read 2498 times)
monkian
Stem Restoration
March 31, 2014, 09:37 AM »
I thought I'd contribute this little resto
It started off as a bit of an experiment but it worked out alright so thought I'd chuck it up.
I hope it's of some use
You might know I bought a stem that was the wrong size so I went out and got this replacement. I took a bit of a gamble on it as it needed some work but I thought I'd give it a go & don't mind using resto parts on a build. Anyhow it turned up like this:
Looking at the base, it's got a textured finish from casting with what looks like a semi-matt type finish so I thought I'd try to recreate it without loosing the texture or stamp definition. I did all the usual prep, clean, de-grease, a bit of light sanding (with a sanding sponge) and I used needle files to work out any small chips etc. Looked in the garage and found an old pot of matt black house paint and a tin of gloss black spray paint so I just mixed together a small amount of both (probably around 60/40 or 70/30 - gloss/matt).
To apply it I used a bit of old tea-towel wrapped around my finger and just dabbed it on. Small dabs, working quite quickly around the whole base. The nice thing is, there's no rush and you can work back over it to even the paint out. Even when it's going off and still tacky, you can use your finger to work out any uneven texture or high points. It sounds like a lot of fuss but it goes off quick so it's no big deal. I gave it three coats, lightly using a bit of wire wool to key between them.
I think I'll work some more on polishing the top but I'm pretty pleased with it so far.
Oh yeah, it's a good idea to think about where to put it to dry...
I got caught out and had to work something out still holding on to it
Last Edit: April 01, 2014, 08:14 PM by monkian
Retrodan72
Site Supporter
BMX Overlord
Re: Stem Restoration
March 31, 2014, 09:45 AM »
Great stuff Paul, top resto, looks ace.
Bet you looked a right tool walking around the supermarket carrying a stem waiting for the paint to dry.
BMX1973
Site Supporter
Berm Worm
That looks a good result.
Top tip with the teat towel. How many layers of dabbing did you do?
monkian
March 31, 2014, 10:25 AM »
Yeah, it was a bit tricky putting my clothes back on
It was x3 rounds of dabbing (drying in-between)...
The first one was just in matt but didn't look right so then I mixed in the gloss
Last Edit: April 07, 2014, 05:28 PM by monkian
oldschoolace
Team Moderator
Double Flip Whip
Bodger
March 31, 2014, 10:33 AM »
Great idea that and cracking results
animal
Team Moderator
BMX Nerd
MRD Loony & proud
March 31, 2014, 10:54 AM »
Awesome
fischflo
900 Air
March 31, 2014, 11:57 AM »
towel resto, i like that!
nice
NORTY40
Site Supporter
Berm Worm
NIL SATIS NISI OPTIMUM
March 31, 2014, 12:36 PM »
Nice resto Paul
WANTED
: Old school BMX patches/sew on badges ...... please
monkian
March 31, 2014, 01:51 PM »
Thanks lads
Tea-towel texture-tastic
kungfunky
Team Moderator
Tail Whip
March 31, 2014, 02:58 PM »
You clever bugger
kang
Curb Endo
March 31, 2014, 04:51 PM »
Looks good
chubby
BMX Nerd
Needs Pegs
Reply #11 on:
March 31, 2014, 07:47 PM »
Looks great that bud, hope you hid the tea towel at the bottom of the laundry basket
rollin72
900 Air
I was a ninja
Reply #12 on:
April 01, 2014, 07:38 PM »
belting
Gashead
Team Owner
Hoffman's Love Child
Up the Gas
Reply #13 on:
April 01, 2014, 07:46 PM »
That's awesome
Gizmo
Rockwalk
Reply #14 on:
April 05, 2014, 06:26 PM »
Nice that looks the nuts
Gary72
Site Supporter
BMX Nerd
Reply #15 on:
April 07, 2014, 09:40 PM »
Great result, I know it's abit late now but I have a block of wood that I have used a 22mm flat bit in to hold a stem when drying. Or cut up a coat hanger and hang it in the oven to bake
monkian
Reply #16 on:
April 08, 2014, 12:36 PM »
Good tip. Nice idea that
I ended up putting a frame in the bottom of the airing cupboard and resting the stem in the headtube.
double chevron
540 Air
Reply #17 on:
April 10, 2014, 09:28 AM »
Nice job, thanks for sahring your clever ideas
Mattdub
Site Supporter
BMX Overlord
Reply #18 on:
April 16, 2014, 09:02 AM »
Looks good does that , good work
Pooch
Tail Whip
funny you should say that..
Reply #19 on:
April 29, 2014, 07:53 AM »
Good work Paul.. Think I'll just hang out in the resto section..
Griff loves BUM..
Stem Restoration
