skway riveting
84freestyler:
--- Quote from: oberonspacefruit on April 09, 2014, 10:07 AM ---if you used that method on the bolt (grinding) then used a dome nut - possibly ground down as well, it would look better than a standard nut and bolt.
--- End quote ---
I,ve considered that too mate, that is a good second option to the rivets :daumenhoch:
84freestyler:
Rivets arrived and in just 5 days from Oz!
Big "Thank You" to wazu007 (he knows why) :daumenhoch:
"So it Begins"
Wish me luck fellow Radsters!
bobbbbsy:
I HOPE IT BLOODY WORKS... :LolLolLolLol:
waza007:
They are NOT wider at one end. FACT
when they get riveted the rivet shaft gets distorted (twisted)
If you try and push the distorted(bent) end through the plastic it MAY crank the plastic.
Ady:
Old thread as needed some advice , so worthy of a bump.. :bump:
Navigation
[0] Message Index
[*] Previous page
Go to full version
