976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 27, 2026, 05:58 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Removing Alloy tarnishing
Author Topic: Removing Alloy tarnishing  (Read 2188 times)
Offline jimwise68
« on: August 16, 2006, 11:06 AM »
Got a pair of alloy hubs that I've cleaned up, looking very shiney but there is a small amount of tarnishing. Looking like small worm runs (best as I can describe).
Can this be removed?
Re: Removing Alloy tarnishing
« Reply #1 on: August 16, 2006, 11:10 AM »
anything can be removed with enough polishing.
Offline jimwise68
« Reply #2 on: August 16, 2006, 11:12 AM »
Ok, can it be removed easily?
« Reply #3 on: August 16, 2006, 11:13 AM »
depends how deep it is. is the alloy laquered, or just plain old alloy?
Offline jimwise68
« Reply #4 on: August 16, 2006, 11:44 AM »
Good question. It is very shiny so might be lacquered. which means I have to get the lacquer off first right!
If they are not lacquered is it simply a case of elbow grease and time, or perhaps a Dremmel?
Offline Zippy
« Reply #5 on: August 16, 2006, 01:59 PM »
I've got a set of Rock Shox Mag 21 Ti forks that have a gold laquer on them. They also have the same worm type tarnish.
I would say that the hubs would be laquered and if you strip and polish them that will solve the problem.
I was going to do this with my forks. Then BMX happened.
Offline jimwise68
« Reply #6 on: August 16, 2006, 05:05 PM »
Cheers Zippy.
so next question is what is the best way to strip them?
Offline sawzall
« Reply #7 on: August 16, 2006, 05:59 PM »
good old nitromors will strip the lac  :daumenhoch:
