976235 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 30, 2026, 02:58 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Glue for decals?
Author Topic: Glue for decals?  (Read 1832 times)
Offline Howser
Glue for decals?
« on: April 21, 2014, 07:16 PM »
Hi,
       I'm hoping someone can help me on which type of glue is best to use to stick decals back down please?    I applied the fork decals but they didn't completely stick down at the top. Won't take much to peel off so I'm looking to remove and re-apply.  The decals are diamond back so are the foil type ones.
What's the best glue to use?
Many thanks  :daumenhoch:
Offline Gizmo
Re: Glue for decals?
« Reply #1 on: April 21, 2014, 07:43 PM »
Not got a clue ??? But if it were me be good ol super glue
Just a dab tho  :)
Is it the fork decals ? ::)
Offline Howser
« Reply #2 on: April 21, 2014, 07:55 PM »
Thanks - I did think about superglue but having messed it up first time I'm worried in case I mess it up again but then can't get them off  :-[.
« Reply #3 on: April 21, 2014, 08:15 PM »
What about Pritt Stick  :-\
Not tried it, way around it not being to messy.
Offline Howser
« Reply #4 on: April 21, 2014, 09:07 PM »
That's not a bad call - cheers.   I'm sure my daughter has got some and will give it a go.
Offline Chapperz
  • Always too slow on the dib dobs!
« Reply #5 on: April 22, 2014, 08:35 AM »
Alternatively, if its not taking you could try...
PVA Glue (white stuff usually used with flat pack furniture)
Contact Adhesive (used to use it at work, think it would be ideal)
Not tried either obviously, but would think they are less agressive than superglue, i know that you would be able to peel the contact adhesive without too much damage if you needed to remove it.
Cleethorpes Old School Ride Out 2018. 14th July 2018
Offline snoopy72
« Reply #6 on: April 22, 2014, 05:55 PM »
Evo stick, contact adhesive would be best, put a small amount on the sticker and a small amount on the frame , wait 10 mins then stick together.
Offline Howser
« Reply #7 on: April 22, 2014, 08:13 PM »
Thanks for the advice guys and I'll give the contact adhesive a go. Will update the post with results once I've done it.
Many thanks.   :daumenhoch:
« Reply #8 on: April 22, 2014, 08:29 PM »
Pre cum works well
Offline snoopy72
« Reply #9 on: April 22, 2014, 08:41 PM »
Pre cum works well
Just popped into B&Q and asked for a tube of pre cum, they said they've never heard of that make glue and never stocked it  ::) but said they would contact there supplier and give me a ring tomorrow  :daumenhoch:
« Last Edit: April 22, 2014, 09:11 PM by snoopy72 »
Offline deeman
« Reply #10 on: April 23, 2014, 09:25 PM »
I would probably be tempted to use clear nail varnish  :daumenhoch:
 :LolLolLolLol: @ Diggler!
