976236 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 29, 2026, 02:12 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Lester mags... top tips needed
Author Topic: Lester mags... top tips needed  (Read 2277 times)
« on: June 20, 2014, 02:34 PM »
Alreet lads, looking for suggestions to maintain the raw shiney side/high spots on a set of lesters if they are powder coated. What do we reckon, labourious masking before powder or labourious dremeling after?
Re: Lester mags... top tips needed
« Reply #1 on: June 20, 2014, 09:54 PM »
 :tumbleweed:
« Reply #2 on: June 20, 2014, 09:55 PM »
Can't help you but maybe SBD would know  ???
Offline chubby
  • Needs Pegs
« Reply #3 on: June 21, 2014, 02:07 PM »
I'd go with laborious masking  clint, dont want slipping dremal scratching the fresh powder  :chin:
« Reply #4 on: June 21, 2014, 02:27 PM »
What about the masking tape pulling off the powder as you remove it?  >:D
Offline fischflo
« Reply #5 on: June 22, 2014, 12:00 PM »
masking, cause you stay in control, the other way is fail and the oooh aaah should've listened to fischflo etc..
powder, cause you stay in control, the other way is fail and the oooh aaah should've listened to fischflo etc..
« Last Edit: June 22, 2014, 12:21 PM by fischflo »
« Reply #6 on: June 22, 2014, 12:03 PM »
Powder then flat em carefully after . Nerves of steel tho  ::)
Offline Redline
« Reply #7 on: June 22, 2014, 01:30 PM »
I would wet spray them... then "draw file" across the top surfaces. I would imagine paint would be easier to work with than powder  :-\
« Reply #8 on: June 22, 2014, 01:49 PM »
Did think about paint as its easy to mask with a liquid mask but would prefer the harder wearing powder. I think sanding after powder is likely to be the best solution  :-\
Offline CustardLips
« Reply #9 on: June 22, 2014, 02:09 PM »
Is it worth the hassle ? They look pretty tidy to me or is that a pic of their good side.  :)
"WWG1WGA"
Offline CustardLips
« Reply #10 on: June 22, 2014, 02:10 PM »
Oh just thought is a change if colour your after.  ???
"WWG1WGA"
« Reply #11 on: June 22, 2014, 04:52 PM »
That's just a stock photo, mine deffo need a restoration. besides I'm thinking of a radberry colour or teal  :-X
Offline Gary72
« Reply #12 on: June 23, 2014, 08:52 PM »
Powder or paint then block sand after. If the braking surface is bad I would give them a sanding before you paint/powder then work your way through finer grades of paper.
