976235 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 29, 2026, 10:23 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Seatpost won't go in -haro gen 1 / gt layback ****`SORTED*****
Author Topic: Seatpost won't go in -haro gen 1 / gt layback ****`SORTED*****  (Read 2462 times)
Offline adammannering
Goes in I say a couple of inches then it just stops man ! It stops !
Have tried wd40 but the frame starts getting HOT - not good
What is correct size seatpost for a gen 1 ?
Many thanks chaps
« Last Edit: July 09, 2014, 07:50 PM by adammannering »
Wanted any condition pk ripper repop for my daily rider !
Re: Seatpost won't go in -haro gen 1 / gt layback
« Reply #1 on: July 09, 2014, 12:55 PM »
hot? what are you doing to it?
is it rusty inside or thick paint?
Offline Dannywhac
  • return of the whac
« Reply #2 on: July 09, 2014, 01:02 PM »
You chaecked for weld blobs/shrinkage inside the seattube where that plate that goes around the seattube? Maybe the frames been repaired and the tubes been 'knocked in' a bit by the reweld?
Also you should use grease not WD40 on seattubes. WD40 sucks the balls etc unless you're using it for a bit of cleaning - as it's not a lubricant.
Offline chubby
  • Needs Pegs
« Reply #3 on: July 09, 2014, 01:02 PM »
Is the remains of an old post in there still  :chin:
« Reply #4 on: July 09, 2014, 01:03 PM »
Not the best way to install a seat post..
Offline Julian347
« Reply #5 on: July 09, 2014, 01:08 PM »
Is the post slightly bent?
Offline antiquebmx
« Reply #6 on: July 09, 2014, 01:21 PM »
you know we want pics
  • Andy
« Reply #7 on: July 09, 2014, 04:24 PM »
There may be some rust inside the seat tube. Might be worth giving it a light sanding down. I use a piece of sandpaper taped to a round piece of dowling wood or the handle of a screwdriver. Do a small bit at a time. Don't go crazy as you want the post to be snug, but still be able to be moved.
Offline Mat
« Reply #8 on: July 09, 2014, 04:31 PM »
This is excellent at getting big things in tight holes  :daumenhoch:
« Reply #9 on: July 09, 2014, 04:50 PM »
cheers for all your replies dudes.
i have inspected the frame and appears to be paint / rust free.
its a gt stamped seatpost 22.6mm see picture.
that anul lube is shi-ite - i lost a good butt plug because of that stuff. - made the bugger perish.
shall i just go ahead and buy a 22.2mm layback ?
who wants this gt layback - i sanded some paint off ( to see if it would help 'entering ' ) - but is still cool. ?
Offline Devilock
« Reply #10 on: July 09, 2014, 04:58 PM »
Yes buy a 22.2 then sing some Barbara Dixon.
Offline Bigfrawg
« Reply #11 on: July 09, 2014, 07:42 PM »
Just smash the coont in
« Reply #12 on: July 09, 2014, 07:50 PM »
chaps - cheers for all advice - i bought a circular file from b&q - it worked, file away, my passage is now clear......and loads of shit came out........fook knows what it was
Re: Seatpost won't go in -haro gen 1 / gt layback ****`SORTED*****
« Reply #13 on: July 09, 2014, 11:46 PM »
If it were me I'd get that clamp a bit higher up/flush with top of seat tube...
« Reply #14 on: July 10, 2014, 07:25 AM »
yeah i know Griff......but cheers....
no bolts tightened really yet, seeing if colours work etc.
not sure on the seatpost actually.  which is a coont.  paid a few bucks for that from the bay.
« Reply #15 on: July 10, 2014, 08:10 AM »
I personally wouldn't leave that post in for the fear that it would get stuck
22.2 would be the right size for the frame so this is always gonna be mega tight and over time it could fuse esp if you been filing so its clean bare metal to bare metal
had one of those gt posts and sold it due to fitting problems
regards
« Reply #16 on: July 10, 2014, 09:52 AM »
cheers brummie - noted dude, thanks for heads up............
