976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 06, 2026, 08:59 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Sturmey archer 3 speed grip???
Author Topic: Sturmey archer 3 speed grip???  (Read 1875 times)
« on: September 23, 2014, 09:21 PM »
Anyone know it you can remove the stock grip and replace with bmx one?
Offline Mat
Re: Sturmey archer 3 speed grip???
« Reply #1 on: September 23, 2014, 09:34 PM »
Are you building Frankenbike mate!?
« Reply #2 on: September 23, 2014, 09:38 PM »
 :LolLolLolLol: super sport commuter Mat  ;)
Offline bigfatolly
« Reply #3 on: September 23, 2014, 10:03 PM »
Maybe try a set of the later Mushroom grips that have the bigger hole?
I will be interested in this as I was thinking of doing a Grifter/BMX hybrid and keeping the 3 speed hub and twist grip.
Offline chubby
  • Needs Pegs
« Reply #4 on: September 23, 2014, 10:46 PM »
Hack the bugger off clint, you must be able to replace em  :teef:
« Reply #5 on: September 23, 2014, 10:56 PM »
I don't remember grifter grips being odd-sized
If they were though, you could always try some of those oury MX grips..?
« Reply #6 on: September 23, 2014, 11:08 PM »
mushroom grips will be no good the ribs go the wrong way for smooth anal insertion, a 4mm allen key will be ideal to scrape the skiddy sweetcorn outa the grooves on that  :LolLolLolLol:
sorry, but it does look like a rubble chute violator  :D
Offline CustardLips
« Reply #7 on: September 24, 2014, 01:49 AM »
Got some blue Oury mx grips Clint if want em. They may do the trick.
Bought from a radster via ebay as bmx grips. Can't remember who tho.  >:(
"WWG1WGA"
Offline snoopy72
« Reply #8 on: September 24, 2014, 07:08 AM »
You can get 8 - speed hubs from sturmey with disc or coaster attachments, I looked into it but would have a serious weight issue especially after frame mods so forgot that idea
Offline dp and chopper dude
« Reply #9 on: September 24, 2014, 09:13 AM »
What about trying a Mk3 Chopper 3 sped grip? They are probably nearer to BMX grip size. I've got one at my Mum & Dad's house. I'm off over there at dinner time. I'll have a weigh up.
« Reply #10 on: September 24, 2014, 11:29 AM »
Cheers Bud  :daumenhoch:
Anyone know if the grifter grip is 22.2mm internal diameter?
« Reply #11 on: September 24, 2014, 01:39 PM »
I've had a nosey and this is what they look like:
To be fair the one you've got looks better. Could you heat up a grip in hot water and slide it over the one that's on the gear selector?
Offline snoopy72
« Reply #12 on: September 24, 2014, 05:53 PM »
should be fine , I fitted a grifter sturmey  to a set of GT pro bars and I removed the grip by cutting it off and fitted a ODI mushroom :daumenhoch:
« Last Edit: September 25, 2014, 07:10 AM by snoopy72 »
« Reply #13 on: September 24, 2014, 10:21 PM »
Moley done a 5sp sturmey to his GT bmx for radchester 2011, it worked well if that's your bag
« Reply #14 on: September 24, 2014, 10:47 PM »
I remember that being talked about, but never saw a pic of it finished
Might be worth a shot if I do another build as I now live on a big fookin hill
Offline Munnyella
« Reply #15 on: September 25, 2014, 09:56 PM »
Slightly oversized, I put burner plastic/foam grips on my grifter when I was a kid, it was a right bollock of a job, but I was 11!.
Mushrooms will be easy, as would most rubber grips, the old MK1 burner grip `cores' were quite rigid!
I also put Fuan cobra grips on it, which was fooking shite as the gear side moves!!
MM
Offline snoopy72
« Reply #16 on: September 25, 2014, 10:02 PM »
I remember having to cut off the grifter grip with a junior hacksaw (hard as nails)
