976301 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 29, 2026, 04:41 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Using diacompe seat clamp as coaster anchor
Author Topic: Using diacompe seat clamp as coaster anchor  (Read 2948 times)
adeshere
« on: August 23, 2006, 10:35 PM »
Not attempted this yet, but looking at the seat clamp, the hole is a lot bigger than the frame of my TA.
has anyone already done this before ?
Do you wrap tape around the frame first ?
DR VINOAH
Re: Using diacompe seat clamp as coaster anchor
« Reply #1 on: August 23, 2006, 10:36 PM »
im sure billy and craig used cut up old inner tubes to take up the slack :daumenhoch:
steve
« Reply #2 on: August 23, 2006, 11:29 PM »
the clamps on renthal crossbars are smaller
-ps they fit mini seat tubes
-mrd - micro stuff, that uses a uni without the shim
« Reply #3 on: August 23, 2006, 11:31 PM »
thats the ticket!!
Offline Steve P
« Reply #4 on: August 23, 2006, 11:31 PM »
Yep . . . old inner tube should do the trick  :daumenhoch:
Renthal clamps are no good as they're not hinged
Steve
dj_benice
« Reply #5 on: August 24, 2006, 10:15 AM »
RL osborn used to use the seat clamp trick see US bmx action january 1984 page 28 bottom of the carrera || review has a close up pic n explains that he uses tape too...
Offline billstup
« Reply #6 on: August 24, 2006, 03:46 PM »
I think I just used insulating tape on mine, lots of it, then the seat clamp over  :daumenhoch:
adeshere
« Reply #7 on: August 24, 2006, 04:33 PM »
Thanks guys, i'll try the sticky tape
« Reply #8 on: August 24, 2006, 04:51 PM »
BITD i used the tape you put onto tennis raquet handles (it was towelling)  :coolsmiley:
adeshere
« Reply #9 on: September 04, 2006, 12:51 PM »
I ended up using a modern alternative.
I put some tape onto the inside of the seat clamp, then shut it up.
I then placed it on to the bench and filled it up with ... No more nails
This then game me a white rubbery material which i the cut to hold the bar.
perfect !
Offline Steve P
« Reply #10 on: September 04, 2006, 01:10 PM »
Good thinking there mate . . . got any pics  :)
Steve
