976234 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 27, 2026, 04:33 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  ad 990 help required
Author Topic: ad 990 help required  (Read 2815 times)
Offline chubby
  • Needs Pegs
« on: November 14, 2014, 04:52 PM »
Hiya kid's can someone tell an idiot the easiest way to get the things working  :whistle:
try & use simple language cos my heads hurting today  Thumbs down
Offline john4130
Re: ad 990 help required
« Reply #1 on: November 14, 2014, 06:56 PM »
put a little grease on the posts, put on the brake arms and tension the springs. about a quarter turn of tension is usually enough, too much and the brake will feel crap. pull out the inner wire from the cable housing and put a little grease on it then put it back in and connect it up. a little grease on the barrel helps too, i dont bother toeing in brake blocks as i like the pads to hit the rim flat. it may squeal but it'll work and get some decent pads. remember grease is your friend.  :laugh:
Offline chubby
  • Needs Pegs
« Reply #2 on: November 14, 2014, 07:10 PM »
BUGGER !!!!!!
Will have to take them off AGAIN to grease  :LolLolLolLol:
Fookin modern brakes  Thumbs down
Offline chubby
  • Needs Pegs
« Reply #3 on: November 14, 2014, 07:22 PM »
Take it I need to tension the arms so the brake block end is towards the wheel ???
Offline Gary72
« Reply #4 on: November 14, 2014, 09:20 PM »
Tension pads/blocks away from rim, Unless you want your brakes on all the time. :)
Offline chubby
  • Needs Pegs
« Reply #5 on: November 14, 2014, 09:35 PM »
I did say I was an idiot !!!!!!
Thanks Gary. Doesn't matter how they're tensioned if I can't sort these rear cables 😬😬😬
Offline chubby
  • Needs Pegs
« Reply #6 on: November 14, 2014, 11:09 PM »
Can't get a good lever feel compared to my caliper brakes, but they seem to work good though
Don't want to tension the springs more than (3/4 turn) I have incase I fook em.
Any suggestions ???
« Last Edit: November 14, 2014, 11:19 PM by chubby »
Offline Gary72
« Reply #7 on: November 14, 2014, 11:19 PM »
Have you done what was said above, Lubricate all moving parts, Cable, Brake arm pivots, Cable barrell where it sits in the lever.
Is there any sharp bends in the cable?
Offline chubby
  • Needs Pegs
« Reply #8 on: November 14, 2014, 11:22 PM »
Certainly have bud only thing I'm not sure about is the odd cable mount thingy. I'll get a piccy a min
Offline chubby
  • Needs Pegs
« Reply #9 on: November 14, 2014, 11:25 PM »
Offline Gary72
« Reply #10 on: November 14, 2014, 11:40 PM »
Never seen a noodle used like that before, I'd try letting off the tension. When you say the feel at the lever, What do you mean?
The more tension you have on the brake arms the harder it will be to pull the lever.
I know on Odyssey brakes the springs are sided, You might have the springs on the wrong side.
Offline chubby
  • Needs Pegs
« Reply #11 on: November 14, 2014, 11:46 PM »
Copied the noodle thingy from this
The lever is nice & easy to pull & the brake actually works/grabs well . It just doesn't go hard (oooooerrrrrr) when the blocks contact the wheel like a caliper brake does. never had 990's before so may just be the way they are ????
Offline chubby
  • Needs Pegs
« Reply #12 on: November 14, 2014, 11:50 PM »
Just re read johns post & too much tension makes it feel poop. Will try slackening it off tomorrow 😉😉😉
Offline Gary72
« Reply #13 on: November 15, 2014, 08:47 AM »
Good morning :LolLolLolLol:
The only thing I can see between the two pics is the tightness of the cable between the arms.
Yours seems to have a curve in it and the red bike looks straight and taught.
Might be that once the blocks hit the rim, then you are getting more lever travel as the cable straightens out, Hope that makes sense.
Offline chubby
  • Needs Pegs
« Reply #14 on: November 15, 2014, 08:53 AM »
Thanks Gary, i've gone to work for a rest !!! Will fiddle again later on. I foooooooookin hate brakes 😁😁
Offline Gordy
« Reply #15 on: November 16, 2014, 12:56 PM »
The other thing to remember is there is two types of springs; a gold and a silver spring.
To get the best out of them, the gold spring goes in the same side as the decal.
Offline chubby
  • Needs Pegs
« Reply #16 on: November 16, 2014, 12:59 PM »
Cheers Gordy, they were brand new & I've not swapped them about but I will check & make sure 👍
Offline Cookiemonster1
  • No way Bells is bigger than Waimea bro
« Reply #17 on: November 18, 2014, 01:16 PM »
Yup Gordy is correct in saying there are 2 colours of spring... one is left hand wound one is right hand wound...if they are in the wrong arm the pads will pull naturally into the rim instead of away as you would expect.
I suspect its lever feel is more mushy than you are used to on calipers due to the extra leverage you get with AD's.
Hope that makes sense! :daumenhoch:
Offline chubby
  • Needs Pegs
« Reply #18 on: November 18, 2014, 01:22 PM »
Certainly does cookie, mushy perfectly describes the lever feel 😆😆
Offline nosepickben
« Reply #19 on: November 18, 2014, 02:25 PM »
If it feels mushy, you will have one, or a combination of these going on;
Soft/misaligned brake blocks,
poor cable line,
insufficient lube,
excessive flex or "take up" in the cable routing,
uneven spring tension in the arms - most common cause, corrected by checking to see if one arm hits the rim earlier than the other. Assuming the wheel is central, then adjust spring tension in one arm only, add or remove tension a bit at a time until you reach an even setting. Use as little tension as possible.
Hope this makes sense!!
Ad's are sh1tloads better than any caliper, once you're used to them.
Offline chubby
  • Needs Pegs
« Reply #20 on: November 18, 2014, 05:11 PM »
poor cable line,
insufficient lube,
Cheers Ben , if I'm honest it's probably got all them things wrong  :LolLolLolLol:
Offline chubby
  • Needs Pegs
« Reply #21 on: November 19, 2014, 10:26 PM »
Hiya kid's.
Done away with the noodle thingy, shortened the cable a bit & followed everbody's advice & BINGO !!! The fooker works that good it's shown up the slightly loose headset that's gonna be a ball ache to tighten 😬😬😬
Offline Gordy
« Reply #22 on: November 20, 2014, 05:03 AM »
Holy shit, that Morales looks awesome.
You have some neat parts on there. Those Kore zero offset forks, kore pegs, peregrine pedals and juice bars are all bad ass pieces. Well done
