976233 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 27, 2026, 01:12 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Correct OGK axle widths and set up?
Author Topic: Correct OGK axle widths and set up?  (Read 1530 times)
Offline Bfellows
« on: November 22, 2014, 01:56 PM »
In a vane attempt to beat my hangover I've just stripped a set of OGKs and need to find out what the correct axle spec is.  Front has caged bearings fitted, rear is loose ball like metal hub tuffs.
Can anyone enlighten me what's correct - Loose ball, or caged?  Correct axle lengths for front and rear?  26 or 28tpi? are rebuild kits available as I need a couple of dust seals.
Ta
Bert
Re: Correct OGK axle widths and set up?
« Reply #1 on: November 23, 2014, 06:58 AM »
IMHO you are better off with loose balls, you get more in there and they run smoother.  Caged bearings are fine but the cages can break up when not maintained and kept well adjusted this results in the cages breaking up and buggering the hub.  I would suspect yours are fresh from the factory with caged on the front (less stress) and loose on the rear (more stress); it's not an unusual combination to have.
Offline Bfellows
« Reply #2 on: November 23, 2014, 11:09 AM »
Cheers Marty, am I right in thinking they are the same as GT wheels?  If so I found a pic that might have answered my question......... could still do with a source for dust seals though........ I'm thinking I could butcher a couple of cheap axle kits for the cones with built in seals?
Offline chubby
  • Needs Pegs
« Reply #3 on: November 23, 2014, 04:59 PM »
Hiya Bert
I used a couple of Bendycats axle kits in mine & they work a treat, got the seals built into the washers & everything.  If you're after the suize dust caps i've probably some somewhere  :chin:
Offline chubby
  • Needs Pegs
« Reply #4 on: November 23, 2014, 05:01 PM »
Offline Bfellows
« Reply #5 on: November 23, 2014, 05:11 PM »
Ta,  here's what came out.......  how much do you reckon looks original?  Nuts are 26tpi.
Offline chubby
  • Needs Pegs
« Reply #6 on: November 24, 2014, 02:21 PM »
Looks like they've been replaced to me Berticles
