976233 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 27, 2026, 01:19 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Skyways dyed patchy!!!
Author Topic: Skyways dyed patchy!!!  (Read 3155 times)
Offline hokuspokus74
« on: December 03, 2014, 11:40 PM »
ive been dying to sets of skways one red and one orange,the red was og white but ur able to peel the dye on the rim of it and its patchy,what can i do with that problem as it seems as if there is like a paint or something on it.
The ones am trying to dye orange were og yellow but there is all patchy bits over both wheels what can be the cause of this,just there was nothing on the wheels to not let the dye take too it how can i get the whole of the wheels dyed properly?
cheers graham :daumenhoch:
Re: Skyways dyed patchy!!!
« Reply #1 on: December 04, 2014, 01:56 PM »
Any pics?
Re: Skyways dyed patchy!!!....Pics Added
« Reply #2 on: December 04, 2014, 02:31 PM »
Heres the pics fooking wheels doing my head in ordered more dye
« Reply #3 on: December 04, 2014, 03:16 PM »
What dye did you use?  Dylon?
« Reply #4 on: December 04, 2014, 03:59 PM »
Dylon on the red & rit on the orange,cant understand why the orange never fully covered them,so what steps do i need to do to correct it Marty :daumenhoch:
Offline bigfatolly
« Reply #5 on: December 04, 2014, 07:28 PM »
Did you use salt as well?
« Reply #6 on: December 04, 2014, 10:52 PM »
Yeah 2 bottles of salt in each
« Reply #7 on: December 04, 2014, 10:57 PM »
Did you keep the water/dye/salt solution at a decent temp throughout?  ???
« Reply #8 on: December 04, 2014, 11:36 PM »
is there a definitive guide to doing this anywhere? I was about to try dying a white Peregrine mag black but this has put me right off.
« Reply #9 on: December 04, 2014, 11:52 PM »
Yeah dan i had the steamer going in it,ive dyed z rims ok the same method as with these,how can i sort them out i dont want to have to leave them in bleach,as i ordered more dye so be here tomorrow or saturday and want the orange to dye,i still think there is paint or some coating on the red ones as when they were white they had a funny feeling to them any ideas on what to do? :daumenhoch:
« Reply #10 on: December 06, 2014, 09:04 AM »
What I would do is strip them using aqua or soda blasting to remove anything that might be painted on.  I've never seen a reaction to the dye like the one you have experienced when doing this before.  I have dyed very faded yellow back to yellow (if that makes sense) with no issues so I think you could be right there must be a contaminant on the surface preventing the dye from being absorbed.
Offline Bfellows
« Reply #11 on: December 06, 2014, 10:25 AM »
I reckon that they have had either oil / wd40 / grease on them at some point through general use and the dye has not took because of that.  Couple of cycles on pot wash through the dish washer with a finish dish washer cleaning bottle instead of tabs is usually enough to strip the grease from most things........
Worth a try before you dye so to speak  ;D
« Reply #12 on: December 06, 2014, 12:39 PM »
Fook The missus would have a heart attack if i used it,wirewool or high graded wet and dry sandpaper will it work,not sure what to do on the rd ones,i dont want to be buying another 20 bottles of bleach to bleach them :daumenhoch:
« Reply #13 on: December 07, 2014, 06:05 PM »
anyone any other options on what i can do?
Offline fischflo
« Reply #14 on: December 07, 2014, 06:44 PM »
Seen that effect on a yellow pair fraz tried to dye blue.
cant ya pour the bleach into a big plastic bag, big enough to hold the wheel, close it and put it in a box with the 'styrofoam beads' or whatchamacallit ....... idea is to reduce the volume of bleach to an amount just enough to cover the rims ........... Caus i guess bleach might be way to go to get rid of the smeary stuff.
or just try the sand paper first, see if it  "help" s :(
« Reply #15 on: December 07, 2014, 10:02 PM »
Right I have to cut in here !
I did a write up of how to dye mags and sent it to graham to help him.
As some of the older members will know that I can dye mags and have had sucsess with my method, also doing a couple of write ups with pictures to show from start to finish !
I tell people that you need to clean these in hot soapy to make sure all foreign items /chemicals are off
You need to realise that grease and brake rub can affect the dye and make it not even in places -
What has happened here is Graham said he did not wash off the bleach and also used grease to cover the alloy hub !
Now people have said in the past to cover the hub with grease to protect it ? I have found that you don't needed it and it can hinder the process !
The grease melts in the hot water and spreads around the mag rim and sticks to them, this is where the grease stops the dying process and makes it look patchy - it's as simple as that !
You can polish the hub back up with wire wool to a original look or close, you can also polish to a slight shine or high mirror shine !
I don't know what the peeling part is ? Brake rub ? Old grease ? Paint ?
Sorry to say I went through all of this last week with Graham
Don't use grease - do a bit more hard work to make the mags look good
Wire wool polish
Polished to a close mirror finish
Back to yellow OGK's
Bunch of Acorns
Back to black
Polished hubs
One set done and one still to do
Third set of reds done
Whites sanded / shaped with razor / bleached
Aero Zytecs back to red
OGK's back to red / polished axle kit
Zytecs to blue
Back to black and polished hubs
Kashi dyed red
And polished guts
Z's sanded shaped and bleached
Original dye charts
More white Z's sorted
More and more white Z's
As you can see I'm not new to the game ; )
Offline fischflo
« Reply #16 on: December 08, 2014, 01:37 AM »
Graham, why won't you listen to Bendy..? :LolLolLolLol:
just one thing:
but what about the pitted flanges you see when bleached and left ungreased.... :-X
« Reply #17 on: December 08, 2014, 01:54 PM »
Greasing up the flanges/alloy hub when bleaching is fine - there is no dye involved at this point !
As of late
Bleaching is fine - but don't leave them in too long ! If after a day or so they are not going whiter, then they won't and they may start yellowing in places !
Aqua spraying is one way, but can put a rougher texture on the mag surface
Peroxide bleaching is another way to bring up dull white mags (no one has tried colours yet ? )
You need sun light for best effect
Dying mags only takes less than a day - so will not pit the alloy !
Cheers B
« Reply #18 on: December 08, 2014, 02:00 PM »
I had listened,never had problems doing z rims or seat but skyways are a real bollocks as they move about too much and pop up out of the water,rite so can i rub the bits on the orange ones with wirewool,acetone,ETC,ETC,
« Reply #19 on: December 08, 2014, 05:37 PM »
You said you never washed them after the bleach ?
I said you need to cover the top of the mags by about 2 inches !
I would try bleaching them first to see if you can take the colour out, wirewool, you might have to do the whole mag or it will be patchy !
« Reply #20 on: December 08, 2014, 06:01 PM »
ah fook that bleaching carryon again 20 bottles fook that,ive the dye here and dont want to be buying dye after dye after dye foothat think i might sand the red ones as i had stated that it had a coating on them etc fooking things
« Reply #21 on: December 08, 2014, 06:14 PM »
20 bottles of what ?  ???
« Reply #22 on: December 08, 2014, 06:22 PM »
bleach that how much it took to cover them when i was trying to bleach them,might bin them,and buy a red set and orange ste
« Reply #23 on: December 08, 2014, 06:31 PM »
Well it should have been 2 bottle of bleach and the rest water ! Don't know who said 20 bottles ?
Bin them if you want, but you are only wasting money, as it would not take much to sort the mags out ! Would seem a shame
« Reply #24 on: December 08, 2014, 06:39 PM »
obv am no good at doing skyways fecking things,i'll see if i can strip them and tape the hubs them see how it goes they prob still will go tits up i know my lucky buddy :daumenhoch:
