976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 05, 2026, 12:36 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Tyre sizing
Author Topic: Tyre sizing  (Read 2070 times)
Offline Jono
Tyre sizing
« on: December 04, 2014, 11:41 PM »
20x1&3/4 same as 20x1.75 are they the same
Jono
Offline Jono
Re: Tyre sizing
« Reply #1 on: December 04, 2014, 11:44 PM »
And if not does it matter will they both fit on same rim araya 7b to be exact
Jono
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
Re: Tyre sizing
« Reply #2 on: December 05, 2014, 12:00 AM »
NO!!
20 x 1 3/4 or S7s are skinny tyres developed for Schwinn they won't fit on a 7B
What year are your 7Bs Jono? Have you laced them yet as some have large spoke holes for heavy gauge spokes?
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
Re: Tyre sizing
« Reply #3 on: December 05, 2014, 12:01 AM »
Offline Jono
Re: Tyre sizing
« Reply #4 on: December 05, 2014, 12:04 AM »
1977 they are already laced although I am putting a coaster hub on the rear so will need to replace it hopefully spokes can be re used
Jono
Offline Jono
Re: Tyre sizing
« Reply #5 on: December 05, 2014, 12:06 AM »
So are they not 20" or are you saying they not wide enough for the rim I sppreciate 1 3/8 are skinned 1 3/4 should be considerably wider..... No
Jono
Offline Jono
Re: Tyre sizing
« Reply #6 on: December 05, 2014, 12:07 AM »
So are they not 20" or are you saying they not wide enough for the rim I sppreciate 1 3/8 are skinny Chris but 1 3/4 should be considerably wider..... No
Jono
Offline bobbbbsy
Re: Tyre sizing
« Reply #7 on: December 05, 2014, 12:11 AM »
1 will go on the other but not vice versa - i forget which. the answer is no .
Offline Jono
Re: Tyre sizing
« Reply #8 on: December 05, 2014, 12:13 AM »
Right so it's a radius thing 20 ain't really 20 then?
Jono
Offline bobbbbsy
Re: Tyre sizing
« Reply #9 on: December 05, 2014, 12:18 AM »
maybe u can - i think i tryed it the other way round .
http://bmxmuseum.com/forums/viewtopic.php?id=429549
maybe that means with rims ? oh im confused now.  :buck2:
« Last Edit: December 05, 2014, 12:20 AM by bobbbbsy »
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
Re: Tyre sizing
« Reply #10 on: December 05, 2014, 12:19 AM »
Typically S7s are low profile tyres (these days) but with a wider bead so they're too big for 1.75 rims - 20 x 1 3/4 only fit Schwinn rims
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
Re: Tyre sizing
« Reply #11 on: December 05, 2014, 12:20 AM »
Porkchop sell 20 x 1 3/4 tyres and have this disclaimer:
* Size: 20" X 1 3/4" (IMPORTANT: These only fit Schwinn S-7 rims... they will NOT fit a 20" X 1.75". This is because a S-7 rim has a 419mm bead diameter and a "regular" 20" X 1.75" or 2.125" rim has a 406mm bead diameter. Although mathmatically the number looks the same, in the world of tire sizing, it is a COMPLETELY DIFFERENT SIZED TIRE. However, 20" X 1.75" TUBES are compatible with these tires.)
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
Re: Tyre sizing
« Reply #12 on: December 05, 2014, 12:24 AM »
That thread is about 1 3/8 tyres not 1 3/4  :crazy2: :LolLolLolLol:
Offline Jono
Re: Tyre sizing
« Reply #13 on: December 05, 2014, 12:27 AM »
Cheers boys just been reading Sheldon brown thingy n yep there's about 10 mm difference in rim so it's s no go cheers guys have to grovel to seller on eBay usa see if he'll csncel my bid lol
Jono
Offline bobbbbsy
Re: Tyre sizing
« Reply #14 on: December 05, 2014, 06:37 PM »
it was past midnight - not responsible.  :LolLolLolLol:
