976233 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 27, 2026, 11:40 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Quietest pads
Author Topic: Quietest pads  (Read 2615 times)
Offline Devilock
Quietest pads
« on: December 19, 2014, 01:31 PM »
I'm not good enough to ride brakeless so can anyone recommend fairly quiet pads?
Currently using Xposure on Cinema rims.
Re: Quietest pads
« Reply #1 on: December 19, 2014, 01:39 PM »
you got em toe'd in Rich?   ???
Offline CustardLips
Re: Quietest pads
« Reply #2 on: December 19, 2014, 01:52 PM »
Why... you riding round the library ?
"WWG1WGA"
Re: Quietest pads
« Reply #3 on: December 19, 2014, 01:59 PM »
all pads will squeal if they're not setup right.  gotta make sure the fronts hit first  :daumenhoch:
Offline Devilock
Re: Quietest pads
« Reply #4 on: December 19, 2014, 02:34 PM »
I have heard that...I'll check.
Cheers Rob.
No the school...
Re: Quietest pads
« Reply #5 on: December 19, 2014, 02:38 PM »
Noisy pads can work well for clearing a path through busy crowds, always found that clear pads on tuffs worked great - saved having a bell  :daumenhoch:
Offline oldtired
  • Dirty Old Man
Re: Quietest pads
« Reply #6 on: December 19, 2014, 07:06 PM »
oddy Ghost pads are ok , black ones , not tried the clear ones ,  already shaped for toe in , but i found they will squeek a bit when you pull up on the brake real hard ,  cured by taking a little bit more off the toe in shape with a file though ,  :daumenhoch:.
the toe in on soft  pads needs to be quite big 3-4 mm , as the soft compound will compress under breaking , and eliminate the toe in gap.
Offline bobbbbsy
Re: Quietest pads
« Reply #7 on: December 19, 2014, 07:11 PM »
i did nt think any modern pads squealed . seems you are the exception  :LolLolLolLol: . exposure are kinda like blank and sc to . kinda poo.
Offline eddie kidd
  • 22 years 23 days 24 minutes
Re: Quietest pads
« Reply #8 on: December 20, 2014, 01:56 AM »
 ;D
Wanted Green Oakley B2 Grips...Nos...
Offline eddie kidd
Re: Quietest pads
« Reply #9 on: December 20, 2014, 01:59 AM »
My son asked me 'What's the noisiest Pads'... ???
Re: Quietest pads
« Reply #10 on: December 20, 2014, 09:13 AM »
SQUEAL BOY  :teef:
Offline Twesnik
Re: Quietest pads
« Reply #11 on: December 20, 2014, 03:04 PM »
 :D :whistle: :daumenhoch: :LolLolLolLol:
Offline oldtired
  • Dirty Old Man
Re: Quietest pads
« Reply #12 on: December 21, 2014, 01:52 AM »
got to be the best interpretation of a reply i've seen  :daumenhoch:  should i of mentioned the clear ones can be quite sticky aswell   :daumenhoch:   :LolLolLolLol:
Offline bmxband1t77
  • '77 a good year (Star Wars-Punk) but not my DOB.
Re: Quietest pads
« Reply #13 on: December 21, 2014, 03:04 AM »
JONBOY likin' this thread. I wondered if clear pads work on tuffs. I've got a colour skyway don't make pads for anymore. Might give it a wizz.
To set toe in easily two ways.
Put credit cards under each pad at the back and pull hard to set blocks on rim.
I've just seen someone wrapping rubber bands around instead.
Despite all this my quad rears fekkin squeeel like a peeeeg
Tank yew
Re: Quietest pads
« Reply #14 on: December 21, 2014, 12:50 PM »
The new skyway pads are quiet, it's not surprising though as they resemble two stick of chalk in appearance, stopping power and durability  ;D
Offline hokuspokus74
Re: Quietest pads
« Reply #15 on: December 21, 2014, 02:53 PM »
Try these pads there pretty quiet  :D :2funny: :LolLolLolLol:
