Dyeing A Repop Kashi.....Anyone Had Success Doing This?
brakedancer:
never used salt cant remember reading I had to on the instructions
never had a problem tho ... the colour was nice and strong and haven't had any rub off....
snoopy72:
--- Quote from: hokuspokus74 on December 20, 2014, 11:43 AM ---I've did 2 dan good results especially dyeing green to black,i had the rails taped up but the heat of the water made the tape come of,after i dried it all off sprayed with wd40...rit dye is the best that i used forget dylon and remember to add salt :daumenhoch:
--- End quote ---
Salt is only used when dying cotton, useless for dying nylon, I contacted Rit, they said for best results add 1 heaped table spoon of non bio washing powder, Rit is only designed to dye within 40 mins, so if it doesn't work after that it will never dye :daumenhoch:(all depends on the grade/quality of nylon)
boiling water and salt will only damage metal items including the pot, I know , I've done it.
Don't leave a seat in longer than the 40 mins or the seat rails end up a baggy fit in the seat :daumenhoch:
hokuspokus74:
I was always told to us e the salt when dyeing,fook sake people give some many indications on dyeing stuff,will need to try it without salt and try adding non bio washing powder
snoopy72:
Came straight from the horses mouth :LolLolLolLol:
dancetothedrummersbeat:
I have a load of RIT in black Dan. Stocked up when I went to Florida. PM me your address and i'll send you some if you like :daumenhoch:
Navigation
[0] Message Index
[*] Previous page
Go to full version
