976232 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 25, 2026, 02:45 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Rear Drop Out Distances
Author Topic: Rear Drop Out Distances  (Read 1530 times)
Offline Flovalwolfie
« on: September 08, 2015, 10:19 PM »
Hi
Does anyone know why a NOS frames drop outs would be 100mm instead of 110mm between each other ? The rear wheel won't fit in-between the drop outs. Or are some hubs narrower ?
Thanks for any help
Offline GS1962
Re: Rear Drop Out Distances
« Reply #1 on: September 09, 2015, 06:37 AM »
I could do also with some help on this very same question. I too just picked up a lovely NOS frame from the early/mid eighties and the rear dropout spacing is only 100mm on that too.
I get that this isn't common but were some frames built this way or is it simply poorly built.......hence NOS?
If it is just an uncommon set up how do you get the rear wheel to fit and stop the freewheel catching the chainstay? If I remove all cone spacers it'll go in wit the freewheel's then too wide. Running Suzue hubs.
« Reply #2 on: September 10, 2015, 02:19 PM »
What frame is it/are they?
Sometimes you need to "spread" the rear triangles apart if the gap is a little short, quite common bitd.
This is a good read:
http://www.sheldonbrown.com/frame-spacing.html
« Reply #3 on: September 10, 2015, 04:24 PM »
try twatting it with a hammer
Offline GS1962
« Reply #4 on: September 10, 2015, 09:08 PM »
Sorted mine.....cold opened the rear out to 105mm and then sprung it open the last 5mm to insert the wheel. Thanks for your help on this one!
Offline CustardLips
« Reply #5 on: September 10, 2015, 09:38 PM »
That is a good read... nice one Marty.  :daumenhoch:
"WWG1WGA"
