976297 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 21, 2026, 02:36 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  HELP PLEASE
Author Topic: HELP PLEASE  (Read 3612 times)
Offline nitrohopper
HELP PLEASE
« on: October 16, 2015, 09:52 PM »
OK so I am parting out the rl20II so I start to take it apart when the stem decided not to come out very easily at all  undid the stem bolt as you do wouldn't budge so then I take the stem bolt right out and oh yes oh now I have a four piece forklifter stem is this normal oh and the Base is still stuck in forks
Sent from my D6603 using Tapatalk
Offline Bfellows
Re: HELP PLEASE
« Reply #1 on: October 16, 2015, 10:00 PM »
Screw the long bolt back into the wedge, piece of wood on top of bolt to protect it the give it a tap / wallop to knock the wedge down from the shaft and it should pull out.  Top looks to be push fit so refit it all and bollock it up to push the stem back on.
Or wait till Clint pipes up.......
Re: HELP PLEASE
« Reply #2 on: October 16, 2015, 10:15 PM »
Berts got it  :daumenhoch:
Is it a fakelifter?
If it's a tight fit put the stem in the oven and the shaft in the freezer should help getting them back together a little  :)
Offline That Swan Guy
Re: HELP PLEASE
« Reply #3 on: October 16, 2015, 10:28 PM »
put it back together and put an old seat post in the stem where the bars should go and twist like fook
Offline nitrohopper
Re: HELP PLEASE
« Reply #4 on: October 16, 2015, 10:29 PM »
So Clint are you telling me it's a fake stem ??  Does this happen a lot or not
Offline Bfellows
Re: HELP PLEASE
« Reply #5 on: October 16, 2015, 10:40 PM »
Is it suntour stamped?
Re: HELP PLEASE
« Reply #6 on: October 16, 2015, 10:45 PM »
Not saying it's fake but the fact that it came apart would possibly suggest that. Unless you have been really swinging at it with a hammer, which I doubt  ???
Offline nitrohopper
Re: HELP PLEASE
« Reply #7 on: October 16, 2015, 11:02 PM »
Not sure until I get the Base out mind u missus is now asleep so there will no hammering tonight I will let you know
Offline nitrohopper
Re: HELP PLEASE
« Reply #8 on: October 17, 2015, 03:28 PM »
removed stem base and yes it is suntour stamped so I can only think that it has been refinished
so now that I have put I back togeather  will it be ok I mean I was riding on it or is now best for show pony
Re: HELP PLEASE
« Reply #9 on: October 17, 2015, 08:07 PM »
How did it come apart, did it  pull off or were you knocking at the underneath with a rubber mallet or something. If the former I wouldn't want to ride it
Offline nitrohopper
Re: HELP PLEASE
« Reply #10 on: October 17, 2015, 10:49 PM »
[/quot
when I was removing it I  didn't knock the stem bolt down once undone so the wedge was wedged it has gone back togeather but I will sell it as a carpet queen special
Offline Bfellows
Re: HELP PLEASE
« Reply #11 on: October 17, 2015, 10:57 PM »
JB weld  :daumenhoch:
Re: HELP PLEASE
« Reply #12 on: October 19, 2015, 12:51 PM »
Knock it out as NOS  :daumenhoch:
Re: HELP PLEASE
« Reply #13 on: October 19, 2015, 01:28 PM »
I would definately strip that finish off and polish all the detail out first, noones going to believe its nos if its painted, you have to be able to see a parallel universe in the finish for it to be NOS. I think!!!
Re: HELP PLEASE
« Reply #14 on: October 19, 2015, 03:39 PM »
 :LolLolLolLol:  good point sir  ;D
Offline deeman
Re: HELP PLEASE
« Reply #15 on: November 22, 2015, 10:16 PM »
Weren't these stems known for spinning on the shaft? common problem?
