976295 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 20, 2026, 08:31 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Fork Crown Race Query
Author Topic: Fork Crown Race Query  (Read 1903 times)
Offline johnjo74
« on: May 24, 2016, 10:31 PM »
I've always found the fork race to be tight as a nun's chuff and require some strategic twatting to remove .... Do they need to be this tight?
The reason I ask is the one I intended to use , just slips on and has a little play in it . I'm pretty sure it's original to the headset I'm using it with (Tange).... I've also tried a different race on the forks which needs knocking on a bit and has no play .
Will the 'loose' fitting one be ok when assembled ?
Offline That Swan Guy
Re: Fork Crown Race Query
« Reply #1 on: May 24, 2016, 10:46 PM »
Sounds like an MX2 headset
Offline CustardLips
« Reply #2 on: May 24, 2016, 10:53 PM »
You want it nice and tight ideally.  :daumenhoch:
"WWG1WGA"
Offline johnjo74
« Reply #3 on: May 24, 2016, 11:12 PM »
Here's the headset...
I've assembled it , without the thin washer and all seems nice and tight .
Thought it might have been cobbled together as I hadn't seen one with the thick threaded lock ring ??
  • Andy
« Reply #4 on: May 25, 2016, 01:02 PM »
They should be a snug fit, but ideally can be removed by tapping them with a happer/screwdriver combo in case you need to re-paint/re-chrome your forks. I've occasionally dremmeled a small amount from the inside of the crown race or shaved a bit off the forks to make it fit
rodriguez
« Reply #5 on: May 25, 2016, 02:03 PM »
There are two sizes of crown race 26.4mm and 27mm, the standard one is 26.4 IIRC.
Sounds like you have a 27mm crown race, I'd just use one from another headset that fits correctly rather than shim it.
Offline chubby
  • Needs Pegs
« Reply #6 on: May 25, 2016, 10:32 PM »
What rod says ^^^^
