976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 20, 2026, 03:03 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Next project - Silver Streak
Author Topic: Next project - Silver Streak  (Read 2516 times)
Offline sparky
« on: May 28, 2016, 08:33 AM »
So I picked this up recently and going to give it a sympathetic resto which means only replacing or adding necessary bits.....even going to keep with the rusty original spokes.  :daumenhoch:
It's pretty much original apart from the rear tyre and only requires minor work.
I need to replace the rear inner DC cable as it's shot, add a pinch bolt/washer and nut, source a pedal dustcap and replace all the cage screws as most are damaged and one is missing. Although the cages are bent, they are staying that way and although the grips are not great their condition add to the bikes history.
If you have anything in your boxes of spares, please let me know.  :daumenhoch:
« Last Edit: May 28, 2016, 08:35 AM by sparky »
Offline sparky
Re: Next project - Silver Streak
« Reply #1 on: June 02, 2016, 10:52 PM »
Getting there.
« Reply #2 on: June 02, 2016, 11:11 PM »
Looking good that mate  8) :daumenhoch:
Offline Mikku
  • Keeping it RAD in Japan!
« Reply #3 on: June 06, 2016, 01:14 PM »
Yeah, a lovely bike and props for going down the sympathetic resto route. :daumenhoch:
Am I right in thinking these frames are tri-moly? & what year is this one?
« Reply #4 on: June 07, 2016, 09:16 PM »
Great looking survivor. Will look great when cleaned up.  :)
Offline Macmania
« Reply #5 on: June 07, 2016, 09:25 PM »
Ace  :4_17_5: love a DB  8)
Wanted: Anything MT Racing
Offline CustardLips
« Reply #6 on: June 07, 2016, 09:26 PM »
Come up lovely that... looking forward to seeing it finished  :daumenhoch:
"WWG1WGA"
Offline sparky
« Reply #7 on: June 07, 2016, 09:34 PM »
Yep Tri-moly, it's an '83  :daumenhoch:
Few more things went back on the last few days but keeping to my quest of only replacing/fixing what is necessary :)
« Last Edit: June 07, 2016, 09:36 PM by sparky »
Offline Mikku
« Reply #8 on: June 07, 2016, 10:48 PM »
Thanks for the confirmation. I've recently seen an '82 one for sale but am ideally after a full chromoly frame. In any case, am looking forward to seeing this one when you're done. :daumenhoch:
Offline sparky
« Reply #9 on: June 25, 2016, 04:58 PM »
All done  :)
All I've replaced are the pedal cage allen screws, DC inner cable, inner tubes and rear tyre (didn't like the all black one). Everything else is original spec/stock survivor but added the original pad-set.
Offline rooski
  • Mons Veneris
« Reply #10 on: June 25, 2016, 05:09 PM »
Superb Mark!
Tis a fine looking bike for sure, probably the closest to spec I have seen!
