976301 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 30, 2026, 09:25 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  1 1/8 forks into 1" frame help
Author Topic: 1 1/8 forks into 1" frame help  (Read 1921 times)
« on: September 10, 2006, 08:45 AM »
is anyone running his set up i have a mid school 1" headset frame and want to run 1 1/8 forks any one done it.is it just afix bearings loose.
revcore
Re: 1 1/8 forks into 1" frame help
« Reply #1 on: September 10, 2006, 09:26 AM »
It can be done....I've done it before on my old Mongoose Solution frame with 1" headtube. I bought a 1-1/8" threadless headset made by a taiwan company called MODUS. I bought it because the cups looked real tiny for a 1/8" headset so I used my 1" cups but used the rest of the 1/8" headset. It was great to be able to run a unique setup that actually worked perfectly.
I wish I could locate more of those headsets but I haven't seen anymore of them for about 2 years.
« Reply #2 on: September 10, 2006, 10:39 AM »
what you need is:
the 1" headcups
the 1 1/8" forks, along with their bottom washer/shim/bit that bearings lean on fitted
the 1 1/8" top parts
2 sets of 1" bearings
then you strip the bearings from their tracks
put plenty of grease in the cups
put the bottom bearings in, loose. you can fit almost 2 1" races in there. but dont dont cram it too full
put the forks back in
put the top bearings in loose
then the top cover / bevelled shim thing, then the spacers then the stem
that will work
« Reply #3 on: September 10, 2006, 10:41 AM »
« Reply #4 on: September 10, 2006, 10:55 AM »
 :daumenhoch: i will give it a go i got a frame not sure what it is looks very much like a standard shorty but its not im sure 1" but would love to build it up .
« Reply #5 on: September 10, 2006, 04:47 PM »
there are a few sets of 1" threadless forks kicking about
but 1 1/8" will go in fine. the OSF used to run 1 1/8" in his old rickman frame too
