BMX General > BMX Chat
building an ugly bike
<< < (8/8)
MartyC:
So, which one is the boat anchor?  :D
It actually looks pretty nice  :shocked:, what does it ride like?
john4130:
--- Quote from: MartyC on November 09, 2017, 01:35 PM ---So, which one is the boat anchor?  :D
--- End quote ---
think it weighs about the same as the boat anchor, only had a little pedal on it but it feels pretty good to ride, plenty room on it and doesn't feel a million miles away from a new school bike.
chubby:
Best thing I've seen in a good while, fookin cracking job John  :smitten:
john4130:
had to do a fair bit of work on this, i removed a couple of plates that had been welded on the rear dropouts up to the brake mounts. i also removed a set of canti mounts of the forks. i made the z rim from an old 4 spoke acs z wheel and the front pegs were drilled out to fit a bolt that fitted the forks. i then made the decal for the chainwheel and made the z rim decals. the paintjob on the frame isn't great, i just did it with some rattlecans.
Andyboy77:
--- Quote from: john4130 on November 09, 2017, 08:57 PM ---had to do a fair bit of work on this, i removed a couple of plates that had been welded on the rear dropouts up to the brake mounts. i also removed a set of canti mounts of the forks. i made the z rim from an old 4 spoke acs z wheel and the front pegs were drilled out to fit a bolt that fitted the forks. i then made the decal for the chainwheel and made the z rim decals. the paintjob on the frame isn't great, i just did it with some rattlecans.
--- End quote ---
That's a special set of skills! I love that.    :daumenhoch:
Navigation
[0] Message Index
[*] Previous page
Go to full version
